2 members (Otto Skorzeny, 1 invisible), 91 guests, and 4 robots.
Topics128,202
Posts1,057,409
Members48,471
Socket Breaker
Socket Breaker
link to the single photo
.... and I get home from work and my spark plug is:
A) unplugged from the wire
B) loose and rattling around in the block
C) broken (as in spinning around freely in the housing)
So... of course while checking the other spark plugs, the spark plug wire on one of them broke apart and I spent like 30 mins putting it back together with the clip and trying to get it to 'snap' onto the dadgum plug... it was in a super weird position.
*sigh*
two of the other plugs were hand tight or loose as well.
WEIRD.
so, I checked each one and snugged 'em all back up and replaced the broken one.
I have no explanation for this one.
old trucks are fun!
right?
-W
You probably had an unexpected passenger in the engine room.
Cat, rat or squirell!!!
It had a sudden urge to depart and mangled your wires.
LOL!!!
Socket Breaker
Socket Breaker
dadgum cats!
-W
Were the gaskets still on the plugs?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
woog, it was mr.Goodwrench on drugs that messed it up.
Hope all is straigtened out and running smoooooth.
Socket Breaker
Socket Breaker
a hot rod guy (chopnchaneled from the HAMB) gave me this tip about the spark plug boots on the wires:
What causes that is when you pushed the boots on the plugs there was an air pocket formed in it and after a period of time pressure builds up and blows the wire off.
What we did to keep it from happening on the race engines was take a needle and syringe after pushing the boot on and slide the needle in the boot beside the plus and draw a little vacuum and it solved our problem.
Makes sense to me on the part about the wire popping off anyway.
Still not sure why the plug broke... I guess I'll keep an eye on it.
-W
