8 members (moparguy, baldeagle, walter74, Sjm, Wooley, SmalltownTRKGuy, Sjm, Hotrod Lincoln, 1 invisible),
342
9
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | How many beers and doughnuts did that cost you? Great video | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | How many beers and doughnuts did that cost you?
Great video 2 Beer!!!! 1 had a game of hockey he was going to, and my dad couldn't stay! Not too bad I say! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | How's your back... BTW that's the best video we've had here on the bolt. A 5 window 3600, must be rare.
~Jim
Great video 2 Beer!!!! 1 had a game of hockey he was going to, and my dad couldn't stay! Not too bad I say! Planning is everything. I had two nephews lift my cab off for me similar to what you just did. When it was time to put the cab back on.....no nephews!!! I had to put the cab back on myself....with a floor jack. Fun times ahead | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | How's your back... BTW that's the best video we've had here on the bolt. A 5 window 3600, must be rare. It's a 3800 (well 1404 Canook version) With 4 guys, it really wasn't bad. Two of us has lifted it the day before but with the shuffling down the length of it, opted to use 4. I must say, I think in this whole teardown, I've had maybe 7 or 8 broken fasteners - mostly small screws. Looking forward now to pulling the 216 and blasting this frame. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Planning is everything. I had two nephews lift my cab off for me similar to what you just did. When it was time to put the cab back on.....no nephews!!!
Fun times ahead Agreed - I made sure everything was ready to go. I'm the kind of guy who wants to do the whole job himself - so I only try to call on help when it's beyond my lifting capabilities! I've also seen video's on here of guys removing them with hoists, a few others building lifts etc - but I opted for speed! My first glance at the bell housing has me puzzled - I'll have to do a bit of reading to understand how its attached to the engine - from first glance it looks like its bolted from the INSIDE of the bell housing to the block... at any rate, I have a few pounds of grease and dirt to scrape off first! | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Today I returned the wrong style brake shoes for my 1 ton.  Gonna have to rethink the process.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I found another speedo drive gear, pressed the old one off, pressed the new one on, installed everything, put the tranny back in, torque tube back, cross member..., put the correct fan on. Put the rad back in, filled the coolant. After all that, I hopped in, started it....oops, no stick shifter, get that in, went for a road test. First legal road test ever for me in that rig, woo hoo!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Congrats Leo. That first ride has to be special. For me I had to adjust the rear doors on my panel. They would come open when I take off. I cut a cork gasket to raise the "strikers" a little bit and also adjust the rods all I could. At least they stay closed now until you pull the hole down. On the 37 I jacked it up to start pulling the rearend. Last Friday night I was coming home and had a need for speed at a stop sign. Man, it sounded like I made cheerios out of the spider gears but it turned out a bottom bolt came out of the shock. A new bolt, some loctite and I'm back in business. YOu talk about a relief, whew, man, I've been happy all day  | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Alvin, you had some good luck. My luck is usually bad. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Aren't these projects fun?
~Jim
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Making travel plans to go back to MS to pick up the truck!!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Didn't spend a whole lot of time today,but managed to try my new wheels for size. New shoes. I'm still shopping for tyres though. When did they get so flippin' expensive? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Making travel plans to go back to MS to pick up the truck!! Robert, doesn't it feel like you're going back to get one of your children I've not seen in months? lol
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... passenger side door latch on the 37 has been hard for my "little short wife" to open so I pulled it out tonight and got it working nice and slick after I took it apart and cleaned and greased it up.
Also put a "final" bled on the panel's brakee. Hope to get it to the front end shop after I get off work tomorrow. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Making travel plans to go back to MS to pick up the truck!! Robert, doesn't it feel like you're going back to get one of your children I've not seen in months? lol YEP!!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Making travel plans to go back to MS to pick up the truck!! Robert, doesn't it feel like you're going back to get one of your children I've not seen in months? lol AWWWWW! Dont ya just love family reunions!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Finished the wiring to the headlamps. parking/directional lights, horns, and power fan on the '53. Hopefully the hose kit for the a/c will arrive today and I can start running them.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I installed the lower door seal. Worked a bit on finishing the bed after the paint touch-up and discovered the 6" SS carriage bolts that go in each rear corner were a bit too short. I ordered two from The Bolt Depot.
~Jim
| | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | Took her out for a spin today. Four blocks down, four blocks back.
Doesn't seem like much, but it's taken me 14 months to get her back on the road after grenading the transmission. Most of the down-time was spent searching for another suitable 3spd. I scoured eBay, Craigslist, swapmeets and repair shops.
I had one shop tell me that they could rebuild what I had so I left it with them. six months later they still hadn't done anything. They were 120 miles away so it wasn't the easiest thing to get it back.
I finally found a donor and then had the replacement rebuilt. Good thing too - the cluster gear was a little ragged.
Now it's all back together and we're getting reacquainted ;-)
Everything is different now...
~Jim
| | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | got the inner to outer cowl panels ready to weld in | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | John, how about a picture tour of this process?
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Except for one piece I have all the pieces to my under the rear spare tire carrier for my panel sand blasted and laying in the cabinet waiting for POR15.
Been a long hot day...whew, to hot for hot dogs so we settled for some BBQ from Charlies BBq over in Greenville....and of coarse PEPSI, and lots of it.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I've got all the parts needed to finish my bolt. However my wife pulled me down to the Texas Hill Country while my bolt sits in Dallas pining for me.
~Jim
| | | | | Joined: Aug 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 88 | Installed new rear axle seals and C washers in the stock rear diff and bolted on new new brake lines on my 52 half ton. Starting tearing down and cleaning the wheel cylinders and master cylinder to see if I can save these parts. Hope to have a complete chassis by the end of the weekend....wishfull thinking! | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Still don't even have my '46 Shorty Bus here yet but I did send a check off for a Cummins 4BTAA with an Allison 545 tranny attached (want to swap that tranny for a 5 speed). Hoping to tune the little smoker for high mpg. Can't wait to get started! | | | | | Joined: Sep 2010 Posts: 1,717 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,717 | I got my stuck motor to turn about 1/2 revolution. I think it's stuck on the rusty ring on the cylinder walls. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | walked out to the garage into the 101 degree heat and made an about face. I believe I'll hold off until tonight when it's in the high 70s.
~Jim
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Pulled off all the brake shoes. Swapped a couple of wheel cylinders. Just have to wait for the shoes to be relined, and she'll be on the road soon after that!
| | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Well one day I will get some pics up but for today I finished removing all of the un-needed brackets in preparation for the M2 front suspension. Next on the list is removal of the steering box/column and scraping of the frame to rid it of all of it's years of grease, grime and dirt then some paint.
Joe
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Finally got a bracket made for the stock air breather that will use a paper element. I have the W-1 carb - so there is no stud thru the bore. Had to fasten bracket to bottom half of breather and drill a hole thru top half for a wing nut. Then decided to "road test" the rest of the afternoon. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Yesterday - Pulled my transmission Today - pulled the pressure plate, clutch and flywheel.
Pulled the starter, generator, water pump.
Building up to the engine pull! | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I finally brought it home!!
2000 miles, severe t-storms with hail & damaging winds and having to navigate the mountains of TN & VA but I made it!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Congrads, now you can spend some "quality" time with her.
~Jim
~Jim
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Waiting on parts also found a five window to replace my 3 window, think I'm going to buy it.
