0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | I had to replace the 3spd transmission in the 1940 Chevy Super Deluxe Conv... I always have a few used ones around(along with everything else...) and I installed a 3 spd with the words, "Rockford McGurk 009 Special" painted on the bottom. The result was unbelievable. 1st seemed higher, second pulled like a team of clydesdales and 3rd "feels" slightly overdrive...
What the hell is this? Possibly a Frank McGurk modified? Any one ever hear of this?
Scratchin' my head with a big grin, Andy
A man is like an old truck... He will rust out before he wears out...
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It's probably a tranny that some guy named McGurk pulled a "Rockford" with and broke reverse. I have an old California Bill book that recommended using a Lincoln Zephyr transmission for the gear ratios, perhaps it is one of those? Does it have a standard GM bolt pattern?
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Regular Chevy 3 spd gear ratios were the same right up into the early 60's,2.94 first and a 1.68 second,third is always direct.Close ratio gearsets were offered for mid 50's Vettes,something around a 2.47 first gear and a 1.50 second gears and some say an even closer set with a 2.20 first gear.These gears can be fitted into the earlier 3 spds,perhaps that's what you got.It's possible McGurk had gears made,if so, your may have some valuable gears,lol. | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | The tranny is sitting behind a stock 216... Thinkin' about how nice it would be behind the 261 :p
Andy
| | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Josiah, it is a GM trans... Next time I have it on the lift, I'll check the ratios.
#7582 01/15/2005 11:50 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Is 1st gear synchronised?
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Yes, it is synchronised... Smooth as heck and it has a much shorter throw, so to speak... like it has a short shift kit. I really want to figure out exactly what it is... Josiah, I'm just about ready to start restoration of the '53 3100 shop truck with a '61 261. What, if any, mods did you make on your motor?
Andy
#7584 01/17/2005 12:40 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My motor is bone stock right now except for a dual point ignition and a 12 volt alternator and a shortened water pump. I need to rebuild it- it smokes a bit and has a lot of gasket leaks. It is still makes good power, though.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | FB,does your car still have the original torque tube or has the car been converted to open driveline?There are really only 2 all syncro 3 spd with a Chevy bolt pattern,Saginaw and the somewhat elusive Muncie. Both are designed for open drivelines. | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Still has the torque tube... I think it has been modified. I may just pull it out and disassemble to see what we have here. Thanks guys!
Andy
