3 members (homer52, 52Carl, FishinToms53), 81 guests, and 3 robots.
Topics128,127
Posts1,056,677
Members48,452
#7577 01/14/2005 2:37 AM
I had to replace the 3spd transmission in the 1940 Chevy Super Deluxe Conv... I always have a few used ones around(along with everything else...) and I installed a 3 spd with the words, "Rockford McGurk 009 Special" painted on the bottom. The result was unbelievable. 1st seemed higher, second pulled like a team of clydesdales and 3rd "feels" slightly overdrive...
What the hell is this? Possibly a Frank McGurk modified? Any one ever hear of this?
Scratchin' my head with a big grin,
Andy
A man is like an old truck... He will rust out before he wears out...
#7578 01/14/2005 8:55 PM
It's probably a tranny that some guy named McGurk pulled a "Rockford" with and broke reverse. grin
I have an old California Bill book that recommended using a Lincoln Zephyr transmission for the gear ratios, perhaps it is one of those? Does it have a standard GM bolt pattern?
Paint & Body Shop moderator
#7579 01/15/2005 1:25 AM
Regular Chevy 3 spd gear ratios were the same right up into the early 60's,2.94 first and a 1.68 second,third is always direct.Close ratio gearsets were offered for mid 50's Vettes,something around a 2.47 first gear and a 1.50 second gears and some say an even closer set with a 2.20 first gear.These gears can be fitted into the earlier 3 spds,perhaps that's what you got.It's possible McGurk had gears made,if so, your may have some valuable gears,lol.
#7580 01/15/2005 1:20 PM
The tranny is sitting behind a stock 216... Thinkin' about how nice it would be behind the 261 :p
Andy
#7581 01/15/2005 1:23 PM
Josiah, it is a GM trans... Next time I have it on the lift, I'll check the ratios.
#7582 01/15/2005 11:50 PM
Is 1st gear synchronised?
#7583 01/16/2005 3:02 PM
Yes, it is synchronised... Smooth as heck and it has a much shorter throw, so to speak... like it has a short shift kit. I really want to figure out exactly what it is...
Josiah, I'm just about ready to start restoration of the '53 3100 shop truck with a '61 261. What, if any, mods did you make on your motor?
Andy
#7584 01/17/2005 12:40 AM
My motor is bone stock right now except for a dual point ignition and a 12 volt alternator and a shortened water pump. I need to rebuild it- it smokes a bit and has a lot of gasket leaks. It is still makes good power, though.
#7585 01/17/2005 1:43 PM
FB,does your car still have the original torque tube or has the car been converted to open driveline?There are really only 2 all syncro 3 spd with a Chevy bolt pattern,Saginaw and the somewhat elusive Muncie. Both are designed for open drivelines.
#7586 01/18/2005 4:11 AM
Still has the torque tube... I think it has been modified. I may just pull it out and disassemble to see what we have here. Thanks guys!
Andy
