1 members (Gray_Ghost),
77
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 20 New Guy | | New Guy Joined: Feb 2011 Posts: 20 | Hi Guys, I'm going to install new glass run channel and felt glass scrapers in my '48 half ton this weekend. I need a little advice on how to install the scrapers. They look like they clip into place? There are clips in the kit I ordered. Thanks, Keenan | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | by clips do you mean staples? | | | | | Joined: Feb 2011 Posts: 20 New Guy | | New Guy Joined: Feb 2011 Posts: 20 | Yes, what are the staples for? Thanks, Keenan | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | They are for fastening the sweeps to your truck.
| | | | | Joined: Feb 2011 Posts: 20 New Guy | | New Guy Joined: Feb 2011 Posts: 20 | The sweeps are inserted into a channel thats welded into the inside of the door. Where do the staples go? thanks, Keenan | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | On my '38 they go through the sweep and the garnish molding to hold the sweep in place. It can be a challenge to get everything lined up & the holes in the right place but it's not impossible. It can be a character building experience.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The sweeps are inserted into a channel thats welded into the inside of the door. Where do the staples go? thanks, Keenan staples go here on the anti rattle strip ...pic... ...pic... Alah Horvath worte a tech tip on installing the window parts ...link... in there he used #4 sheet metal screws instead of staples, some have posted using pop rivits instead of staples Good luck | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I glued mine on. No problem after a year. Denny Graham also has some info on his site about stapling them on. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Denny is a detail oriented kind of guy. He's got a lot of good info to share.
