4 members (jaycoop, Gdads51, Otto Skorzeny, Shade Baby), 96 guests, and 2 robots.
Topics128,131
Posts1,056,367
Members48,441
#756867 06/23/2011 4:14 AM
Hi Guys,
I'm going to install new glass run channel and felt glass scrapers in my '48 half ton this weekend. I need a little advice on how to install the scrapers. They look like they clip into place? There are clips in the kit I ordered. Thanks, Keenan
by clips do you mean staples?
Yes, what are the staples for? Thanks, Keenan
Ex Hall Monitor
Ex Hall Monitor
They are for fastening the sweeps to your truck.
Tiny #757209 06/24/2011 3:09 PM
The sweeps are inserted into a channel thats welded into the inside of the door. Where do the staples go? thanks, Keenan
Ex Hall Monitor
Ex Hall Monitor
On my '38 they go through the sweep and the garnish molding to hold the sweep in place. It can be a challenge to get everything lined up & the holes in the right place but it's not impossible. It can be a character building experience. smile
staples go here on the anti rattle strip
...pic...
...pic...
Alah Horvath worte a tech tip on installing the window parts
...link...
in there he used #4 sheet metal screws instead of staples, some have posted using pop rivits instead of staples
Good luck
I glued mine on. No problem after a year. Denny Graham also has some info on his site about stapling them on.
Ex Hall Monitor
Ex Hall Monitor
Denny is a detail oriented kind of guy. He's got a lot of good info to share.
Moderated by  ndkid275, Phak1
