8 members (Oldpickupman, 41 chev, 51sub, Gdads51, Charles in CA, Nick in Manitou, TUTS 59, 1 invisible),
103
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 90 | Hi Folks,
There is quite a few shops making 8 lug to 10 lug adapters so that people with modern dually pickups can mount Big Rig 22.5 or 24.5 rims.
Question is if there anyone making it for the 6 lug (6-8.75)?
Ah, they adapters for the 8 lug ones are really expensive so there is maybe little to no incentive to get one for the 6-lug. I.e. is it better to get hold of later HD axels which has 10-bolt already?
Cheers Dyna
PS: I'm just contemplating which way to go, since the single biggest expense putting the truck back on the road will be wheels and tires. A new hydrovac is cheap comparing it to the wheel and tire cost. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can already get 22.5" 6 lug Buds wheels, so no need for adapters. | | | | | Joined: Jul 2010 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 90 | :), I know you can but only in one size, if you want to go say aluminum or wider wheel you can't. The recommended size for the 6-lug wheels are only 9", which isn't the most common size nowadays. Beside I have a hard time finding them as you might know  Cheers Dyna
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | If your truck is a 60 or later an axle swap is a good way to go but 59 and earlier that is a though one you would most likely have to narrow a front axle to get one that didn’t put the tires outside the fender wells. The rear would be an easy find and swap though. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Do a search hear on the board there have been discussions about adapters and I think that someone a wile back was having some made. Also Grigg narrowed the front axle for his 48, it takes advanced skill and should only be attempted buy the most skilled welders and no matter how good the job is done it best not show because I bet no DOT inspector anywhere would pass a front axle that was thought to have been cut and welded. | | |
