3 members (Nick in Manitou, Sjm, 1 invisible), 88 guests, and 4 robots.
Topics128,264
Posts1,058,356
Members48,485
#755377 06/17/2011 6:23 PM
Hi Folks,
There is quite a few shops making 8 lug to 10 lug adapters so that people with modern dually pickups can mount Big Rig 22.5 or 24.5 rims.
Question is if there anyone making it for the 6 lug (6-8.75)?
Ah, they adapters for the 8 lug ones are really expensive so there is maybe little to no incentive to get one for the 6-lug. I.e. is it better to get hold of later HD axels which has 10-bolt already?
Cheers Dyna
PS: I'm just contemplating which way to go, since the single biggest expense putting the truck back on the road will be wheels and tires. A new hydrovac is cheap comparing it to the wheel and tire cost.
You can already get 22.5" 6 lug Buds wheels, so no need for adapters.
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #755418 06/17/2011 9:44 PM
:), I know you can but only in one size, if you want to go say aluminum or wider wheel you can't. The recommended size for the 6-lug wheels are only 9", which isn't the most common size nowadays. Beside I have a hard time finding them as you might know smile
Cheers Dyna
dyn_ares #755662 06/18/2011 11:40 PM
If your truck is a 60 or later an axle swap is a good way to go but 59 and earlier that is a though one you would most likely have to narrow a front axle to get one that didn’t put the tires outside the fender wells.
The rear would be an easy find and swap though.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Do a search hear on the board there have been discussions about adapters and I think that someone a wile back was having some made. Also Grigg narrowed the front axle for his 48, it takes advanced skill and should only be attempted buy the most skilled welders and no matter how good the job is done it best not show because I bet no DOT inspector anywhere would pass a front axle that was thought to have been cut and welded.
user
