2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#753605 06/10/2011 5:48 PM
Hey Guy's,
I have a 51, 235. That's a Babitt pounder. Does anyone have a favorite place to get pistons and rings from? Beside Jim Carter. Or any engine parts for that matter. I'm thinking about putting new pistons in.
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
GEC52 #753617 06/10/2011 6:43 PM
Try Kanter Auto Parts or Ross Racing Pistons if you want to spend some extra money. Even NAPA can supply them and probably Rock Auto Parts.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #753622 06/10/2011 8:15 PM
Keep in mind 1954-62 aluminum pistons fit and are easier in the rod bearings with there lighter weight.
My Blog
Pre '68 Dave #753623 06/10/2011 8:21 PM
If they are newly made, they will probably be aluminum. My 216 replacement pistons were made by Egge and they are a different design. The rings that fit are much thinner then the old design.
1951 1 Ton Completed
GEC52 #753700 06/11/2011 2:54 AM
There are usually several sets of 235 pistons on Ebay at any particular time. Do you plan to rebore the block, or try to replace the existing size pistons? If so, do a careful measurement of the bore size and taper to be sure the new ones will fit right and the rings will seal.
I used TRW, forged aluminum. Sourced them from my locally owned parts store, which tends to have better access to older vehicle parts.
Bill Burmeister
