7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP),
111
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75322 03/24/2007 6:31 AM | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | Guys. Help me out here. What do I do about the location of my shifter now that I have the saginaw four speed tranny in my truck? The shifter comes up underneath my seat.
I really want to keep the stock look of my bench seat. I've thought about "looping" the shifter around the front of the seat and then curve it back up so the knob is directly above the shifter insertion point. That way I should still be able to push the shifer down to put it in reverse... right?
I'm desperate. I can either drive it tomorrow, or tear out the tranny and look for a T-5 and start over. PLEASE DON'T MAKE ME START OVER! Driving it tomorrow seems like a much better idea.
Thanks.
Mainjet | | |
#75323 03/24/2007 6:33 AM | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | P.S. I've already modified the base of the seat frame so there is nothing in front of the shifter. I've got room to make a custom shifter to go foreward, up then back over the seat cusion as long as this will allow me to push it down for using reverse.
Anyway... I await your comments.
Thanks agian,
Mainjet | | |
#75324 03/24/2007 3:12 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | Back in the day when I was young factory cars with 4 speeds and bench seats came with the shifter curved to miss the seat so just modify it to your needs,,I have done it in the past with round rod and covered it with black wire loom covering the plastic with a slit...doc | | |
#75325 03/24/2007 8:55 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Check the vendors page for a listing for Patricks Antique Cars or somethign like that. He sells a shifter designed for a Saginaw 4-speed in a truck. It should solve your problem.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#75326 03/26/2007 4:07 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | When I ran the Saginaw 4 speed in my old truck, I had to shorten up the shift rods and also make a new bracket. This moved the shifter foreward and it worked fine. | | |
#75327 03/29/2007 9:57 PM | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Originally posted by JiMerit: When I ran the Saginaw 4 speed in my old truck, I had to shorten up the shift rods and also make a new bracket. This moved the shifter foreward and it worked fine. I made this bracket by cutting out 3X3 angle iron and drilling some holes to shorten the throw. The up-over-up portion places the shifter in the middle of the floor in an AD cab. You can see here how I bent shifter arms and shortened shifter dogs (I made my own) to decrease the overall shifter throw. No, this isn't a Saginaw like what you have but it is an example of making a shifter fit to where you want it.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#75328 04/07/2007 4:41 AM | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | Cosmo, Thanks for the pictures.
I took the easy way out. I bent a big 'U' into my shifter. It actually looks like the old "arrow through the head" that Steve Martin used to wear.
The seat fits where your head would go and shift knob is where your girl should be sitting (booo!), but it works and I didn't have to screw up my seat. I was worried about being able to push down for reverse, but it works fine. I wish I knew how to put the links into a message and I'd show you my 20 minute solution to what I thought was going to be a major problem. Been driving her ever since... Well until we got the sleet and snow today (darn this weather).
Thanks guys. | | |
#75329 04/08/2007 3:41 PM | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hello all, Grant here. I have the original 235 in my 59. I have a 3:42 10 bolt out of a 90's Caprice, with a Saginaw 4 speed, late 70's vintage, that I plan on installing behind the 6. I have the needed driveshaft yokes from late 80's S-10 Chevy. My question is... is the bell housing plane of the engine at the same location if it's a 6 cyl or a V-8? When I had the trans out last summer, I did some preliminary measuring, and found too that the Hurst trans shifter will not fit the floor insert. I have bucket seats, so it is not as important of location with bench, but the truck is so clean that I want to cut as little as possible. My long term plans are for a stock v-8, with the 4 speed. If the bell housing planes are the same, I will only need to cut the floor once. Otherwise I'll wait for the 4 speed and the V-8. What do you guys think? Grant. | | |
#75330 04/08/2007 6:05 PM | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Grant, The V-8 bellhousing mounts in the same location as the 6 cyl on TF trucks and doesn't change the relationship between the transmission, driveshaft, shift linkage or clutch linkage. Fred
#75331 04/09/2007 2:53 AM | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | rfs56trk, thanks, that was the info I was hoping to hear, it will speed up my installation schedules greatly. Grant. | | |
