| | | Forums66 Topics128,114 Posts1,056,607 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 97 | Hood is setting high at cowl area on 56 3200. It has a new cowl gasket. Are there different gaskets? It seems rather high. I can't get any more adjustment from the hinges. Any hints? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...just be glad you don't have my AD to deal with! Ugh | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the cowl top seal won't affect positioning, it crushes easily .... the more likely problem is you have worn hinge pins, which allow the back of the hood to move up because of the spring tension - if the hood opens and closes well and lays right with the springs off, but stands proud at the back with the springs on, you need new hinges
Bill | | |
