1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | So I am doing the 235 engine conversion on my '51 3100. The 235 is out of a '55 second generation. I purchased the water pump conversion plate and new water pump. Instructions on the pump conv. plate indicate I need a harmonic balancer from a '53 or '54 so pump and fan will run at the proper speed. Both my generator and new water pump have 3/8" belt fittings. I have an old harmonic on my 216 but that is 5/8". Any sources for a new or used harmonic balancer or do i just return the pump and plate and go with the new short shaft water pump?? | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | If you can return the pump or exchange it another option is to use a 1952 or earlier pump with the 5/8 pulley and use your 216 balancer. Depending on your generator/alternator/voltage choice you may have to change the front pulley on that too. I went with a 216 balancer, 1952 pump with adapter like you have, and took the pulley off my 6 volt generator and put it on my 12 volt generator.
Chuck | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Thanks Chuck, that is looking like a pretty good option at this point. I have the 216 to grab parts from so I may go that route. Mark | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Chuck, Just wanted to verify that the balancer from the 216 will fit the 235 and that it is the correct size. Thanks, Mark | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you can also check with Tom Langdon.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Mark, I know it fits but I have not run the engine yet. All the people with actual experience say the 235 and 216 balancers are interchangeable.
Chuck | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I've got a 55 power glide 235 in my 52-3100 and did the Pre-68 Dave adapter and used a 216 water pump, I used the balancer off my 216 and used a 3/8s belt with no problems others here have also used the 3/8s belt with no problems,using the stock 216 water pump instead of the short shaft pump if you ever need a pump out on a trip you can order it from any FLAPS it's cheaper and most places can get one in 1 day.My truck is converted to 12volt alt. and the 3/8s belt is fine.
Pete | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | My instructions also say you can use a 1955-62 truck balancer if you are running a 3/8" belt.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2011 Posts: 21 New Guy | | New Guy Joined: Feb 2011 Posts: 21 | Thanks everyone, I do appreciate it! Mark | | |
