4 members (Rich'sToys, Bill Hanlon, klhansen, 1 invisible), 55 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#752742 06/07/2011 4:16 PM
So I am doing the 235 engine conversion on my '51 3100. The 235 is out of a '55 second generation. I purchased the water pump conversion plate and new water pump. Instructions on the pump conv. plate indicate I need a harmonic balancer from a '53 or '54 so pump and fan will run at the proper speed. Both my generator and new water pump have 3/8" belt fittings. I have an old harmonic on my 216 but that is 5/8". Any sources for a new or used harmonic balancer or do i just return the pump and plate and go with the new short shaft water pump??
If you can return the pump or exchange it another option is to use a 1952 or earlier pump with the 5/8 pulley and use your 216 balancer. Depending on your generator/alternator/voltage choice you may have to change the front pulley on that too. I went with a 216 balancer, 1952 pump with adapter like you have, and took the pulley off my 6 volt generator and put it on my 12 volt generator.
Chuck
Thanks Chuck, that is looking like a pretty good option at this point. I have the 216 to grab parts from so I may go that route.
Mark
Chuck,
Just wanted to verify that the balancer from the 216 will fit the 235 and that it is the correct size.
Mark
you can also check with Tom Langdon..
Redryder pix
My Hotrod
Mark, I know it fits but I have not run the engine yet. All the people with actual experience say the 235 and 216 balancers are interchangeable.
Chuck
I've got a 55 power glide 235 in my 52-3100 and did the Pre-68 Dave adapter and used a 216 water pump, I used the balancer off my 216 and used a 3/8s belt with no problems others here have also used the 3/8s belt with no problems,using the stock 216 water pump instead of the short shaft pump if you ever need a pump out on a trip you can order it from any FLAPS it's cheaper and most places can get one in 1 day.My truck is converted to 12volt alt. and the 3/8s belt is fine.
Pete
My instructions also say you can use a 1955-62 truck balancer if you are running a 3/8" belt.
My Blog
Thanks everyone, I do appreciate it!
Mark
