0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#751234 06/01/2011 6:01 PM
Recently removed the gas tank from my Chev 1/2 ton, had to strip the internal coating which showed signs of some flaking. Externally the tank looks new with a thin coating of either galvanize paint, not sure. Anyone know what is the best to cover the exterior. Should it have a primer? I have it sanded down to a nice shiny surface.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Eastwood has a cadmium paint for gas tanks. Tank Zone I think it is called. I believe you can go over bare metal.
Builder #752568 06/07/2011 1:42 AM
Blanch53, what did you use to strip the internal coating in your tank?
And, the outside of mine looks good except for a few spots where the straps were. Do I need to take the whole tank down to bare metal before putting a coat on?
And, I bought some "hammered" metallic spray paint to use on the interior. Do I need to use special tank paint for the gas tank? If so, is this to allow for breathing as the tank "sweats"? I ask because I noticed that the cab wall behind the tank has surface rust, where as the rest of the interior is clean. I'm wondering if I should use the tank stuff back there as well.
I'm very new to this sanding and painting business, so THANKS for any advice you can give. And hope it is all right for me to ask this thread instead of posting another. They seemed related. :-)
Thanks!
