8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle),
106
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | in my panel. Got it from Jim Carter and it fit like a glove...even got the Stovebolt discount when I ordered it! Chris FYI: for the link to Jim Carter's site and many other vendors, go to Links , then Parts, then GM Specific | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Are all your lines and everything hooked up? These aftermarket tanks have been reported to have metric fittings. Please let us know if these issues have been corrected. | | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | Woody lines are in and same threads in tank as original. Yes I had heard that some tanks from other parts folks had metric ... not the case from Carter. Chris | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | What kind of external coating will you give your tank if any?, and will you use a primer. Just cleaned out my tank for internal recoating and now considering something for the external surface which I have sanded down to a clean finish
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I used rattle can undercoat on my '38's tank before reinstalling.
| | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | I did nothing...If I had it would have been out of one of those rattle cans. Chris | | |
