4 members (‘37ChevyPU, Steelonsteel, dt235sd, carbking), 67 guests, and 1 robot.
Topics128,051
Posts1,055,766
#751165 06/01/2011 9:21 AM
I have a 48 Chevy PU. I am not sure what engine is in it. I was told it has a 235 and it's not the original engine. I need to make sure. I tried researching it but I'm still not certain.
The valve cover has 4 screws, two on each side of it holding it down.
The numbers just above the starter on the block say:
072I589F54Z but these numbers don't seem to correspond to anything meaningful.
Can anybody steer me in the right direction?
1950 Chevy 3100 5-Window
1946 Chevy Panel 3/4 Ton
hefdog #751167 06/01/2011 10:10 AM
It's a 1954 235 "regular" engine built in Flint, MI and used in a car (manual transmission and mechanical lifters).
http://chevy.oldcarmanualproject.com/chevyresto/5409.htm
tclederman #751193 06/01/2011 2:51 PM
This truck has the 4 speed w/granny gear in it. So this engine has apparently matched well with drive train setup for a truck all this time. How do you know it is a 235 engine? I can't tell exactly from the information.
hefdog #751200 06/01/2011 3:40 PM
Engine section of the same car manual.
All 1954 car engines were 235s. Some had hydraulic lifters (Powerglide equipped) and some had mechanical lifters (as did the truck 235).
216/235/261 engines are fairly easily interchangeable over all the years (37-63). Some modifications have to made when 55 and later engines are put into earlier trucks. Depending on the years, some modifications have to made to the motor mounts. 216/235/261 all have the same bolt pattern for attaching any year clutch housing or automatic transmission.
