1 members (KEVINSKI),
124
Mod | | | Forums66 Topics128,130 Posts1,056,706 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75107 03/20/2007 2:22 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Five bolt, six bolt, eight bolt, ten bolt, twelve bolt, fourteen bolt, not being an insider, I sure do get mixed up then you guy throw around these cryptic descriptions. The nephew is a four-wheeler and he’s always talkin’ the talk also, so to be polite I just pretend I know what he means. Now of course, if your talking about five bolt, six bolt it’s obvous that you mean lug bolts/nuts that’s pretty straight forward so lets skip that! But when you jump to the center section that’s where it gets foggy to me. When you say it’s a ten bolt, twelve bolt, fourteen bolt rear end, do you mean ten bolts in the cover or ten bolts in the pumpkin itself?? I think that there are people that are swapping these terms about as they see fit also. So what’s the official industry wide assignment for the location of those BOLTS??? Denny Graham Sandwich, IL
Denny G Sandwich, IL
#75108 03/20/2007 2:28 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Usually it means the number of bolts holding the ring gear onto the differential case in GM products, the more bolts the larger the ring gear diameter & strength should go alone w/that. Ring gear diameter is usually used to ID for parts actually. And yes, I hear alla time "that's a 10-bolt cause theres 10 bolts on the cover" when its actually a Dana rearend. Brian | | |
#75109 03/20/2007 10:58 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What's the deal Denny, you want to upgrade your old bolt? If so I have a couple of 10 bolts I could turn loose.
~Jim
#75110 03/20/2007 11:37 PM | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | whats the difference between a 8.2 10 bolt 8.5 or 8.875 etc etc how do i know what i got?? i think mine is an ex camaro 10 bolt axle with a 3.23 gear but i have no idea about 8.5 8.2 etc | | |
#75111 03/21/2007 12:00 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#75112 03/21/2007 2:32 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Just to make sure its clear, the relationship between the number of bolts holding the cover on, and number of bolts holding the ring gear on, is commonly used on Salisbury type GM rears.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#75113 03/21/2007 4:04 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I give up! Now we got 10 bolts in the cover and 10 bolts in the pumpkin and 10 bolts in the ring gear. I guess I should have heeded the old adage, “if it don’t stink, don’t stir it!” We started out with two interpretations and now we’re up to three. Funny, every time I go to the sites that specialize in rear ends, they always show the rear covers when they identify a rear end. After spending a few days looking over Drivetrain’s site a few weeks ago I thought I had it figured out, but a few of the recent threads on rear ends made me wonder. Drivetrain says; “The following figure presents differential cover/cover gasket shapes. Counting cover bolts and cover shapes is a common method to determine which ring gear diameter differential you have in your rear wheel drive vehicles.” So when I hear 10 bolt, 12 bolt etc. , I‘m gonna assume the person generating the question or reply knows what he is talking about and that they are looking at the cover and counting bolts! Denny Graham Sandwich, IL
#75114 03/21/2007 6:07 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Denny Graham: I give up! Now we got 10 bolts in the cover and 10 bolts in the pumpkin and 10 bolts in the ring gear. Either you're trying to be funny or you need to spend some more time learning the lingo LOL! In your thread starting question you refer to the center section. The center section and pumpkin are the same thing. That piece has a number of common names but differential is probably the best. The strength of a differential is relative to the diameter of the ring gear and commonly given in inches, as in the 9 inch Ford or 8.25 GM. Another way to classify strength (and ring gear diameter) is the number of bolts required to hold the ring gear and in Salisbury GM differentials they are are grouped into strength class by the number of those bolts. 10 bolt, 12 bolt and 14 bolt are the sizes you most often see. Generally on those rears the number of ring gear bolts and cover bolts are the same. While the number of cover bolts may help identify other rears, far as I know its only on the GM Salisbury rears that there is a direct relationship between the count of cover bolts and ring gear bolts. Have I made it better or worse?
#75115 03/21/2007 7:12 AM | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Call Summit Racing at 800-230-3030 and request a free catalog. There is a wealth of information in the ring & pinion section, including the bolt pattern for the covers on GM and other makes. | | |
#75116 03/21/2007 11:31 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have noticed that these terms are thrown around quite a bit in the magazines. The one that I see turning up the most is the "nine inch Ford" or in short form "the nine inch". I think in Hot Rodder's heaven, there are only nine inch Ford rearends allowed! | | |
#75117 03/21/2007 4:02 PM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Most folks that "throw the terms around" honestly dont' know and are afraid to ask!!! Denny, you probably did the Stovebolt world a favor by asking...at least for some!! | | |
#75118 03/21/2007 4:09 PM | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Robin58...That's a perty good link. Helped clear it up for me. Looks like another website to go in my "truck" folder.
Thanks, ~Ron | | |
#75119 03/23/2007 1:14 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Fred and Munk, you get the point. Seems like every one has their own inturpritation of how to apply the terms. Like a few have chimed in with here, if you state the bolt pattern, and the ring gear size then we have a pretty good Idea of what your talking about. Can't speek for the rest of ya, but I'm about 10 bolted out on this subject!!! Denny G.
