7 members (frogfarmer, Hotrod Lincoln, 52Carl, KEVINSKI, Cletus1950, 1955 1 Series, fonz8261), 118 guests, and 2 robots.
Topics128,177
Posts1,057,060
Members48,460
in my panel. Got it from Jim Carter and it fit like a glove...even got the Stovebolt discount when I ordered it!
Chris
FYI: for the link to Jim Carter's site and many other vendors, go to Links , then Parts, then GM Specific
Are all your lines and everything hooked up? These aftermarket tanks have been reported to have metric fittings. Please let us know if these issues have been corrected.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Woody, I put one of Jim's tanks in my panel over a year ago.
I figured it came from Mexico but I must say... it's one of the best repop's I've seen and matched two old ones I had like a glove.
It was NOT metric.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0167.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Fueltanks002.jpg
Woody lines are in and same threads in tank as original. Yes I had heard that some tanks from other parts folks had metric ... not the case from Carter.
Chris
What kind of external coating will you give your tank if any?, and will you use a primer. Just cleaned out my tank for internal recoating and now considering something for the external surface which I have sanded down to a clean finish
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Ex Hall Monitor
Ex Hall Monitor
I used rattle can undercoat on my '38's tank before reinstalling.
I did nothing...If I had it would have been out of one of those rattle cans.
Chris
