| | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 3 New Guy | | New Guy Joined: May 2011 Posts: 3 | hello, i have a 66 fleetside shortbox and want to have a shop install power steering for me. would anyone know what a fair cost estimate would be?
thanks!
skidaddyoo | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Complete, all parts & labor, between $800 and $1000. Fred
| | | | | Joined: May 2011 Posts: 3 New Guy | | New Guy Joined: May 2011 Posts: 3 | thanks for the quick reply Fred. i bought my 66 a little over 3 months ago, and have it fixed up pretty good so far to be a daily driver. the steering upgrade is next. | | | | | Joined: Jan 2011 Posts: 30 New Guy | | New Guy Joined: Jan 2011 Posts: 30 | do it yourself, it will save you a decent amount of money and it will not be that difficult on a truck. i just recently put power steering in a 69 roadrunner, i had to get the steering box from a salvage yard and got it redone by redhead steering which is one of the best steering companies in the u.s. http://www.redheadsteeringgears.com/ i got the pump/pulleys/and brackets through a catalog. and overall i saved a couple hundred bucks from doing it myself and a shop will charge you alot more for parts and the labor fees.
2007 2500HD Duramax crewcab 1965 3/4ton 4x4 1960 1/2ton 2wd
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | You did not mention if you have a 6 or 8 cylinder. Conversions on the V8 are fairly easy; the pump brackets are available from a number of sources. CPP has a complete kit that makes it simple.
Getting the pump brackets for my ’66 292 took some time to find.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | There is a person on e-bay selling brackets for the 292 I6. Price is resonable too! Search power steering 292 chevy, and you will find it.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you can weld, it's very doable...I did my 64 years ago along with a sway bar, make a new truck out of it. Scott | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Great for the hot rod look, but not close to the factory stuff. Thanks for the heads-up. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | 4-5-6 did you move your shop over on Southwest Blvd
You Learn more Listening than Talking
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | the one on ebay has it's problems it seems as it utilizes one belt for pump and alt. there doesn't appear to have that much belt contact on the pulleys, which will cause slippage that is how it appears on the photo of the 230-250 i6 setup ron | | | | | Joined: Jun 2011 Posts: 1 New Guy | | New Guy Joined: Jun 2011 Posts: 1 | Concerning the brackets on Ebay, I have seen several factory and hotrod applications where the belt wrap on the alternator was less than 90 degrees and they worked fine. As the add states, the brackets have plenty of front to back adjustment to account for different belting arrangements. In other words, it works with multiple belts as well. The pictures currently show this. If you have any other questions, feel free to email me. Thanks, Bryan | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
| | | | | Joined: Dec 2009 Posts: 37 New Guy | | New Guy Joined: Dec 2009 Posts: 37 | i put the power steering pump from an astro van in mine, works great and only took 1 day | | | | | Joined: Oct 2010 Posts: 24 New Guy | | New Guy Joined: Oct 2010 Posts: 24 | Did you have to fab any brackets? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | 4-5-6 did you move your shop over on Southwest Blvd I live on the Blvd. and keep a few of my 4-5-6 Chevy trucks over there, but my shop is one block north of 11th & Kansas Avenue in Kansas City, KS. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
