4 members (Erniegp, Rusty Rod, Rich'sToys, dt235sd), 86 guests, and 3 robots.
Topics128,054
Posts1,055,780
#748142 05/19/2011 2:07 AM
I got a 1951 Chevy Canopy Express, 235 w/ 4 speed, when i start the truck in nutral the truck moves forward while starting and it doesnt roll very good when i have the clutch pushed in with it in gear, like there is a big drag. I just got the truck running after 8 years or so of sitting in a field.
Any ideas?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
Take the inspection cover off and get someone to push in the clutch and gently pry the disc loose from the flywheel.
I unstuck the clutch on my 55 after sittin for years by starting it in gear with the pedal pushed... Instant freedom.
Put it up against a strong cement wall. rev it up and let the clutch out slowly and try to break it loose by burning the clutch a bit. Check all adjustments.
