| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 1 New Guy | | New Guy Joined: Nov 2008 Posts: 1 | 57 chevy truck with 235. Am changing to a non-stock carb and will need to use cable actuation. Need advice on converting stock pedal/linkage arrangement to cable, etc. Any successful stories out there? Any suitable "kits"? | | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | Lokar has the setup you need. Google "Eliminator Floor Mount Throttle Pedals". I think Summit and Jegs sells them.
| | | | | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | I ended up at pick a part and harvested several pedal/cable setups from various trucks. Then picked the one that worked the best for my app and shaped a chunk of hard maple into a mounting block and bolted the pedal to that. It works very well now on my small block and q-jet. Not sure about your specific app though. | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | I was thinking of using the Lokar spoon setup on my 57 with a 283 and Edelbrock 650. Besides looks, is there a difference in the spoon and eliminator floor mount pedal?
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
| | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | other than appearance that is the only difference spoon and eliminator . have just fitted eliminater to my sons 56 chevy an easy job looks good black pedal black carpet needed a 48inch cable to reach the holley everything mounted up really good used lokar double return spring and mounting bracket. my son rhys preferrred this type ovrer the spoon which I have in the 50 as it is shiny and his foot slips off it on the highway so eliminator it is | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | sorry forgot to mention mounting of the pedal's is different . spoon has 2 bolt mounting with a cable exit thru the firewall 3 holes in total , eliminator has one exit point thru the toe board that incorporated 4 mounting holes no hole required for cable | | |
