2 members (78buckshot, Wheelie), 131 guests, and 2 robots.
Topics128,128
Posts1,056,358
Members48,441
57 chevy truck with 235. Am changing to a non-stock carb and will need to use cable actuation. Need advice on converting stock pedal/linkage arrangement to cable, etc. Any successful stories out there? Any suitable "kits"?
Lokar has the setup you need. Google "Eliminator Floor Mount Throttle Pedals". I think Summit and Jegs sells them.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
I ended up at pick a part and harvested several pedal/cable setups from various trucks. Then picked the one that worked the best for my app and shaped a chunk of hard maple into a mounting block and bolted the pedal to that. It works very well now on my small block and q-jet. Not sure about your specific app though.
I was thinking of using the Lokar spoon setup on my 57 with a 283 and Edelbrock 650. Besides looks, is there a difference in the spoon and eliminator floor mount pedal?
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
U
U Offline
other than appearance that is the only difference spoon and eliminator . have just fitted eliminater to my sons 56 chevy an easy job looks good black pedal black carpet needed a 48inch cable to reach the holley everything mounted up really good used lokar double return spring and mounting bracket. my son rhys preferrred this type ovrer the spoon which I have in the 50 as it is shiny and his foot slips off it on the highway so eliminator it is
U
U Offline
sorry forgot to mention mounting of the pedal's is different . spoon has 2 bolt mounting with a cable exit thru the firewall 3 holes in total , eliminator has one exit point thru the toe board that incorporated 4 mounting holes no hole required for cable
