1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#746770 05/12/2011 7:33 PM
Z
Z Offline
Have a probably dumb question?I have an original Harrison radiator in my 51Chevy.And I cannot find the drain plug? I was wanting to install a temp sending unit, need to drain the radiator.Any help out there?Thanks
Riding in the Passing Lane
It should be close to the bottom facing forward at an angle. If there is no petcock it may have a pipe plug in it or part of the petcock is broke off. You can remove the plug & put in a petcock. If someone has soldered over it you will need to pull the lower hose loose. Have a large pan. It will get messy.
1972 Chevy c10 Cheyenne Super
My petcock is located on pass side front of lower tank, the lower hose enters at the pass side rear of the tank. My radiator is also a Harrison.
Ed
Forty9 #746961 05/13/2011 11:51 AM
Z
Z Offline
Thanks,for all of the respones,guys. I will check the locations mentioned. I am thinking I will have to go with a big PAN! Thanks for all the comments,and you all,have a great weekend.
There might also be a drain/petcock on the lower-right of the manifold side.
I don't have one either on a aftermarket radiator from Jegs.
Just have to drop the hose SLOWLy
Z
Z Offline
Thanks,everybody for your responses. I found the draincock,on my 51,I couldn't see the forest for the trees.It was exactly where,Forty9 said his was located. The transmission cooler was obstructing the view,but not where I couldn't get to it.Drained the radiator,and got my temp sending unit installed. Thanks again.
if you still have it drained it would be worth while to open the drain cock on the side of the block and drain it. remove the drain cock from the block and rod and flush out all the crap that's been accumilating in there for years.
Z
Z Offline
51 ashton,Thanks,I don't have the original 6cyl engine.I have a 350 small block in there now. The original temp sending unit,was really strechted out to reach,the one on the 8cyl location,so I had to get one for a 8cyl. You are right about the flushing out.The engine I have in there now had just been rebuilt.Thanks
