| | | Forums66 Topics128,275 Posts1,058,439 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74735 03/13/2007 5:22 AM | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Hello Stovebolters, need some help, I have a rear axle housing from 81 Camaro with 2.41 ratio. Question: I intend to run a 350/350, with 215/70/15 or 225/70/15 tires. This is going to be a daily driver, but still would prefer power over mileage. Another option I have is use a S-10 T-5 transmission. So just wanted to know if anyone else has had any experience with the "tall" gear set up and what do you think? Thanks in advance. Phil | | |
#74736 03/13/2007 3:19 PM | Joined: Feb 2000 Posts: 5,268 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,268 | Do a check of the web for gear ratio calculator. There are a lot of them out there. Just feed your numbers in them and see what happens. Also, what trans did the Camero have? What tire size did it have? Joe | | |
#74737 03/13/2007 4:26 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That '81 Camaro was probably a 350/350 or maybe a 305/350. What are you building and how will it be different than the Camaro?
Assuming you're working on an old truck performance is going to be similar to the Camaro with the same engine mods and tires.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#74738 03/13/2007 4:33 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here is the calculator I like. http://www.drivetraindirect.com/t_gear_calculator.htm I use it to find rear axle and overdrive ratios that work together to give me the cruising down the interstate speed I want at an RPM that gives the engine the best economy and a long life. If you find a transmission that works well with the rear ratio you have you can still have the lower gears needed to race from light to light, and the top gear for good fuel mileage. Grigg | | |
#74739 03/13/2007 4:36 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Originally posted by OldSub: you're old truck performance is going to be similar to the Camaro with the same engine mods and tires. True, if the weight of both are close. If your truck is much heaver you may want lower gears in the rear to help haul the extra weight. Grigg | | |
#74740 03/13/2007 4:38 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I would think that 2:41 would be OK with a 350 or any other 1 to 1 tranny.But with an overdrive unit you would need to go somewhere around a 3:73 gear.I am running a 350 SB,and 700R4 OD tranny,with 3:90 gears.It gets decent performance and gets 20 MPG all day long.I am sure you will get other opinions here,but that is how I would go. | | |
#74741 03/13/2007 5:57 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Grigg: if the weight of both are close Yeah I rashly assumed a 1/2-ton pickup that's not likely to weigh even as much as a bloated Camaro, but is also unlikely to weigh a lot less. I made that assumption in part because if its a bigger truck that Camaro rear is a mistake...
#74742 03/13/2007 6:31 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I've had an '81 Z28 since I was 19. It came stock with 350/350 and 3.08 gears. It weighs pretty close to 3600 pounds. Base coupes were a few hundred pounds lighter and Berlinettas were in between.
Advance Design 1/2 ton pickups weigh approx. 3100 lbs. Suburbans: 3600 +-, 3/4 ton pickups: 3480 +- Weights vary slightly from year to year. | | |
#74743 03/13/2007 7:13 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like they are about the same weight. I just assumed a sporty car would weigh less than a pickup. Grigg | | |
#74744 03/13/2007 8:48 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think it would be geared too high. The o-drive would be useless. I run a 350 with 700-4r & 3.08 rear end in my 70 stepside. It is just right but could not handle anything higher. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#74745 03/13/2007 9:05 PM | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | I'm going to run 350 w/ T400 tranny and 3.08 rear end. Given the calculator I've used on Randy's Ring and Pinion web site, I should be cruising right along at about 2200 rpm's at highway speeds. Looking forward to getting the differential put on the truck. | | |
#74746 03/14/2007 3:46 PM | Joined: Feb 2000 Posts: 5,268 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,268 | I run a 250 six with a 350 trans 3.08 gear and 235/75R15 tires, mine gets 18 to 19 mpg and can run 70 mph all day long. Its a little slow pulling a trailer but still gets down the road! Joe | | |
#74747 03/15/2007 3:57 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Well, with those gears you are definetly on the economy side. I would think you would find it difficult to pull a load, or climb a grade. If you ever plan to use it like a truck, you would want to get a lower geared rear end. 3.08 without overdrive, or 3.55 - 4.11 with overdrive should give you "the power" that you are looking for. | | |
#74748 03/15/2007 2:49 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I would think that 2:41 would be OK with a 350 or any other 1 to 1 tranny.But with an overdrive unit you would need to go somewhere around a 3:73 gear. 3.08, 3.40 or 3.73....... 2.4 is pretty highly geared you'll be great on the freeway but hills may be interesting.. my.02
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#74749 03/15/2007 4:06 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Think about the gears themselves too. With a 2.41, even a 3.08, the gears themselves get pretty thin. If you ever want to haul anything, it will be a dog, and the gears have a lot more strain on them (not as strong).
My 327, 2 speed automatic with 3.73 gears will haul and go 75mph. Gas mileage takes a crap at those speeds, but I can take off pretty good too. Mileage around town is going to suffer with too high ratio also.
2.41 IMHO is way to high. | | |
#74750 03/16/2007 5:54 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Hard to believe you have a 2.41 in a Camaro...most V8 Camaros had 3.40 and up rears. With that high a ratio you'll be lucky to get up your driveway and you'll certainly never get that motor going enough to use any OD gear...that's a true flatland only gear! | | |
