4 members (Phak1, TUTS 59, Hush, JW51), 93 guests, and 2 robots.
Topics128,095
Posts1,056,069
Members48,433
#746582 05/12/2011 1:55 AM
Iv tried searching the fourms but didnt have much luck....
I have a 53 GMC and the pervious owner kind of riged up a electric one speed wiper motor and now the wipers can not be positioned correctly for them to work. One is up while the other is down. The motor arm spins 360 degress and both arms are connected the single motor arm.
How is the original one set up to make the arms turn inversely of eachother? Are there two motors? Any pics?
Paulski #746623 05/12/2011 4:12 AM
Welcome to the Stovebolt Paul. I'm sure some GMC guys will help you out. I have a 52 chevy and while I think they may be about the same I do not know for sure. Good luck.
The motor arm on the old vacuum wipers turned through a partial circle, then back, rather than moving through a full circle. Each wiper arm linkage was connected to opposite ends of the wiper motor arm. That way as the motor arm turned one way it pushed both wiper arm linkages out, moving the wiper arms out of the park position and across the glass. Then it would reverse direction and pull the arms back into the park position.
Clear as mud?
twotone #747085 05/13/2011 10:32 PM
What's the best (price and fit) aftermarket 12 volt wiper motor avail. today? Let's say for a '52?
'52 3100 "once a Marine, always a Marine!!
Panhead59 #747091 05/13/2011 10:46 PM
Leo Offline
Moderator
Moderator
I think they run anywhere from $175 up to $250 for the electric motors for my 1953 Chevy. I found a NOS vacuum unit last weekend for $10. but I lucked out.
LMC has them for $150. page 60
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
My vote goes for Newport Engineering. about 185 through JimCarter. Be sure to as for one that clears the choke cable if it applies to your truck.
