1 members (Peggy M),
105
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | Hello, I was told that I could use 72 chevy ft. spindles & disc brakes set up on my 65 ? I was also told to use the 72 ball joints ? Does anyone know if this factory 72 setup will bolt to my 65 ? Thanks, Jerry | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I got '71 spindles/ball joints on mine, works well-I used the tie rod adapters from CPP instead of using the later steering assembly(tie rod ends are a diff size) | | | | | Joined: Nov 2010 Posts: 32 New Guy | | New Guy Joined: Nov 2010 Posts: 32 | Yes, use the upper/lower control arms off the 72 and just put the spindles on and your done..Thats exactly what I did and it works. | | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | I changed the whole crossmember with linkage, control arms, spindles,discs,etc. from a 73-87 1/2 ton. pretty much bolted right up. | | | | | Joined: Dec 2009 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 18 | I have a 64 and am also thinking about doing this with mine. Anybody know if the stance is the same? do you still use the stock coil springs? If I did the whole crossmember swap and then used some 2.5" drop spindles for the 73-87 would it be the same as putting them on the stock suspension?
Better yet, has anybody used drop spindles with the 73-87 crossmember swap?
| | | | | Joined: Dec 2009 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 18 | Thanks Markb, I noticed that thread the other day but was hoping to avoid reading all of it to get the info i'm after. But i'll take a look through it. | | |
