1 members (Gdads51),
128
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,379 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | From what I have read on this forum some of you swear by this stuff. Is it really as good as you say? How well do you prep the area before painting with this. How many coats do you normally use before top coating? Any other advise when using it? | | | | | Joined: Dec 2010 Posts: 15 New Guy | | New Guy Joined: Dec 2010 Posts: 15 | As with any applied product, it is 90% preperation and 10% application. The only thing I used it for is my Fenton Headers, I first baked them in an oven at 500 degrees for 30 minutes, let them cool and applied the Por-15 for exhaust, when it was still tacky, I applied the second coat, I let them dry for 2 days and baked them in the oven again at 500 for an hour. After a year of daily use, they still look like I put in on yesterday. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I've used POR products extensively throughout out my build. Remember POR stands for paint over rust. As Steve(ole5ogmc) mentions preparation is the key(pun intended) Thankfully my chassis and cab underside were in pretty good shape,with just a light coating of rust. I've single coated my chassis and underside of the cab,without a top coat as I have no intentions of the sun seeing the underside. (It has UV sensitivity) I had my headers sand blasted before I painted them,and the engine was steam cleaned thoroughly before I painted it. I've brush painted rather than sprayed and the finish is excellent.
Stick with the POR instructions and it's hard to go wrong. I'm really pleased with the results.
Oh and DON'T forget the gloves! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Did the chassis and several other pieces with POR and I'm pleased with it. Metal must be clean. I like it. | | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | I hear you about the gloves. My right hand is salt and pepper colored. Even the laquer thinner doesn't help after a short period of time. If it's alright to use on the engine it must be heat resistant??? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If it's alright to use on the engine it must be heat resistant??? There is a specific POR-15 paint intended for engines as there is for headers POR-20 . I used Chevy Orange for the block,other colours are available. Here's how they look. Picture . 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Zero rust does pretty good too. I think the best bang for the buck is Rustoleum it is an alkyd enamel, and actually is pretty hard stuff too. And a UV protectant can be added to it.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | Plan on using what is in the can if you will be storing it for a while. Even a little air with turn your leftover paint into iron. Seal the can with some plastic wrap or the lid will be welded on. Otherwise, this tuff is great! Tuff as nails and easy to apply. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | next time I use por15 I'm going to drill me hole in the center of the can, mabye a 1/4" and pour it out as I need it..... then stick a piece of duct tape back over it to keep the air out....Some other bolter suggested this a while back. I have a pint size can of it I think I'll try it on. | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Same here, It is a great product, But the contents in an opened can can harden on you, I wipe the surface clean then put on the lid, Then put a zip lock bag over the can when i'm done. Seems to work.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Mar 2011 Posts: 58 New Guy | | New Guy Joined: Mar 2011 Posts: 58 | Can you get you local paint shop to put it in an aerosol can? My local shop can do the same for Mar-hyde as well. They are pretty similar products. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I POR-15'd the frame and under side of the cab on my 39 Pickup over 10 years ago.. it still looks like new, except where I scratched it all up.
I spent several days cleaning the frame with a wire wheel, then used oven cleaner and finished with a power washer.
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Are there other suggested ways to prep surface rusted metal prior to application other than oven cleaner...once the surface has been sufficiently brushed or wire wheeled?
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | |
