1 members (DES57), 119 guests, and 3 robots.
Topics128,193
Posts1,057,257
Members48,466
Junior Member
Junior Member
I need a drivetrain for my 37 truck,
Plan on using a 350 crate motor. Truck will driven around town and on the highway,150 miles
round trip to work. No plans to paint,gonna leave it looking like I found it,(Barn for 40 years)
The local pull and pay just got in a 90 something
z28,planing on grabing the rear...its complete
and clean. I allready have a 200r trans...but
the trans and converter,flex plate are still on the Z. Should I pull them also along with the driveshaft? What about the powerbrake booster,and
master cylinder,can this be mounted in the frame?
Is there anything else I should grab?
I can Fab up anything,thats no problem. The last transplant I did was in 1978,I need to be a little
more Picky with this one.
Any Thoughts???
Wick
Every Hour you spend Fishing adds
A Day to your Life!
The driveshaft will not be needed, you can have one made, it would very unlikely that the Z would have the right length. Also, check the width of the axle before you buy it, a better swap would be from a '73-'79 Camero/Firebird as they are the right width and still standard bolt, not metric. What about front axle, keeping it stock or adding disk brakes, or M-II?
All the brake adapter kits use the older 73-79 calipers and rotors, at least mine does, and a Ford bearing to adapt them to the straight axle spindle.
My '37 does just fine with manual disk/drum brakes. I have heard power brakes can be touchy, check in the other forums, there is a thread going about adding power boosters. Joe
wick37, I used a Malibu 79/80. I used my original springs, with 3 inch lowering block. I did have to "offset" the lowering block hole about 2 inchs,(I'd have to measure to be sure) then the malibu rear end fit right on top of it. Right width etc. Its ran good for the past 6 or7 years ....until last weekend. I twisted it up but think the shift kit I'm running in my 700R4 had weakened it. I plated my original chassis on the front and put a fabricated crossmember under it with fabricated spring towers. I got all the stuff off a 78 STang II and rebuilt or used it for a core, and it has done well. I put the mastercyl and booster under the driver floor board. Used original stang calipers(new rebuilt) and got after market rotors with chev 5 lug pattern....hope all this helps in some way. Good luck on your project. There are a lot of "pros" here to help you with just about anything.
Note: I offset the rear end lowering blocks to center the rear wheels in the fender.
I would get everything off the Z that you are upgrading on your truck... to include all the widgets in the brake system... dont forget parking brake stuff too!! shifter linkage?
Another quality post.
Real Trucks Rattle
