2 members (Frank50, Kilted54),
71
Mod | | | Forums66 Topics128,189 Posts1,057,222 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74280 03/05/2007 12:43 PM | Joined: Jan 2007 Posts: 27 Junior Member | | Junior Member Joined: Jan 2007 Posts: 27 | I need a drivetrain for my 37 truck, Plan on using a 350 crate motor. Truck will driven around town and on the highway,150 miles round trip to work. No plans to paint,gonna leave it looking like I found it,(Barn for 40 years) The local pull and pay just got in a 90 something z28,planing on grabing the rear...its complete and clean. I allready have a 200r trans...but the trans and converter,flex plate are still on the Z. Should I pull them also along with the driveshaft? What about the powerbrake booster,and master cylinder,can this be mounted in the frame? Is there anything else I should grab? I can Fab up anything,thats no problem. The last transplant I did was in 1978,I need to be a little more Picky with this one. Any Thoughts??? Thanks Wick
Every Hour you spend Fishing adds A Day to your Life!
#74281 03/05/2007 4:31 PM | Joined: Feb 2000 Posts: 5,238 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,238 | The driveshaft will not be needed, you can have one made, it would very unlikely that the Z would have the right length. Also, check the width of the axle before you buy it, a better swap would be from a '73-'79 Camero/Firebird as they are the right width and still standard bolt, not metric. What about front axle, keeping it stock or adding disk brakes, or M-II? All the brake adapter kits use the older 73-79 calipers and rotors, at least mine does, and a Ford bearing to adapt them to the straight axle spindle.
My '37 does just fine with manual disk/drum brakes. I have heard power brakes can be touchy, check in the other forums, there is a thread going about adding power boosters. Joe | | |
#74282 03/06/2007 4:30 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | wick37, I used a Malibu 79/80. I used my original springs, with 3 inch lowering block. I did have to "offset" the lowering block hole about 2 inchs,(I'd have to measure to be sure) then the malibu rear end fit right on top of it. Right width etc. Its ran good for the past 6 or7 years ....until last weekend. I twisted it up but think the shift kit I'm running in my 700R4 had weakened it. I plated my original chassis on the front and put a fabricated crossmember under it with fabricated spring towers. I got all the stuff off a 78 STang II and rebuilt or used it for a core, and it has done well. I put the mastercyl and booster under the driver floor board. Used original stang calipers(new rebuilt) and got after market rotors with chev 5 lug pattern....hope all this helps in some way. Good luck on your project. There are a lot of "pros" here to help you with just about anything.
Note: I offset the rear end lowering blocks to center the rear wheels in the fender. | | |
#74283 03/06/2007 4:49 AM | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I would get everything off the Z that you are upgrading on your truck... to include all the widgets in the brake system... dont forget parking brake stuff too!! shifter linkage?
