7 members (1955 1 Series, Rudedog53, wilbur53, Oswald, Phak1, Charles in CA, Stewart2),
67
Mod | | | Forums66 Topics128,181 Posts1,057,191 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I bought this rolling chassis about a month ago. It's a '41 GMC with a 248, 6 cylinder. After about an 18 year sleep I actually got the motor running. Need to do a better tune-up but it runs pretty good for being out in the elements for that long. And the motor was froze when I got it! Watch me fire it up right here.. And here's an encore performance here. This is too cool!
| | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | How did you get it unstuck? I've been hearing good things about a 50/50 mix of ATF and Acetone.
Any tips and tricks to share? | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Dally, The motor was froze solid when I got it. I soaked each of the cylinders with 2 or 3 tablespoons of ATF. After about 4 or 5 days, I got the motor to budge just a fraction of an inch. I just kept working it back and forth, back and forth, back and forth until I got it to spin freely with out the spark plugs. With my thumb over one of the spark plug holes I could feel the compression and I knew it was gonna run.............and it does. | | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | Did you mix the ATF with anything? or just drop it in by itself?
(Young Gun Question again: ATF=Automatic Transmission Fluid, Correct?)
'54 chevy 3100. In pieces now. .... I've always liked puzzles -Gig em Aggies! Class of 2013
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | CONGRATS! Ain't that fun? | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | That is so cool you got it running after all that time. Those engines were built right. | | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Dally, The motor was froze solid when I got it. I soaked each of the cylinders with 2 or 3 tablespoons of ATF. After about 4 or 5 days, I got the motor to budge just a fraction of an inch. I just kept working it back and forth, back and forth, back and forth until I got it to spin freely with out the spark plugs. With my thumb over one of the spark plug holes I could feel the compression and I knew it was gonna run.............and it does. Thanks John! | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | It would take every thing I had not to strap a lawn chair to that thing and take it for a spin.  | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Automatic transmission fluid | | | | | Joined: Dec 2010 Posts: 34 New Guy | | New Guy Joined: Dec 2010 Posts: 34 | Sure runs smooth after all those years. I was expecting to see lot of white smoke until all the ATF burned off. Thanks for posting. Good inspiration for the rest of us.
46 Chevy 1 1/2 ton
