6 members (Samantha, tclederman, TUTS 59, Otto Skorzeny, Mike Roache, Steelonsteel), 48 guests, and 4 robots.
Topics128,036
Posts1,055,458
Members48,422
#742208 04/25/2011 2:35 AM
LDO
Offline
I'm thinking of doing a PS conversion. Info/advice on which kits?
Anything I need to consider with regards to motor mounts, lowering? Specifically, a 57 3100 with the original V8 (283) conversion front motor mounts. I plan to upgrade to a 350 (zz4) so should I look at the side motor mounts? If so, which ones? Future plans are to go with a 3" dropped axle. Any known issues there? I appreciate all the info/help. Ran a thread search but came up empty.
Many thanks!
LDO #742216 04/25/2011 2:48 AM
chassis engineering offers several side engine mounts that bolt or weld, right in the chassis rail. When I did my 52 I think they showed them for TF trucks to. I love the ones for my 52 but then my 52 was never set up for a V8 like the 55's and up. Still, it may be worth a look.
Achipmunk #742307 04/25/2011 2:13 PM
Are you contemplating IFS? If so would it be a clip or ready-made like Fatman, TCI, or Heidts?
~Jim
LDO
Offline
no IFS. Keeping stock axle.
LDO #742331 04/25/2011 4:11 PM
I recommend the Toyota PS conversion. I installed mine 10 years ago. It has been trouble free and handles great. Numerous aftermarket suppliers can furnish them. I use ABS in Orange, CA.
www.abspowerbrake,com.
FRed
rfs56trk #742370 04/25/2011 6:11 PM
LDO
Offline
rfs,
checked the site. Only found kit #577, not sure if that's the toyota or not.
LDO #742632 04/26/2011 4:09 PM
That's it. The box is from a 84-87 Toyota 4X4 pickup. You will have to modify your existing column or use a later column. I used my existing column and was able to retain the 3 speed column shifter.
Fred
rfs56trk #742769 04/27/2011 2:00 AM
Z
Z Offline
rfs56trk,the 84-87Toyota 4x4 steering box you are talking about,do you just remove original steering box,on the AD trucks,and put the Toyota,back in the same location. I have a 72Chevelle steering column linked in with my original steering box on a 51Chevy 3/4ton.I have 350 engine sitting there with hugger headers. Any info would be appreciated.I have the power steering kit that Achipmunk,has on his Suburban.I don't have it installed yet. Looking for a better way to install without having to remove the fender on the driver's side.Thanks
Z71Chevy #743195 04/28/2011 4:29 PM
I think you should stay with your existing kit as it is a proven system for AD trucks. The Toyota box mounts on the inside of the frame and since the AD frame is narrower than on TF trucks you will more than likely have clearance problems with a V-8. It may work with a 6 cyl but I have not done one.
Fred
rfs56trk #743422 04/29/2011 1:51 PM
Z
Z Offline
Thanks,Fred for the info.I checked on the price,of the Toyota kit,from ABS company,990.00 plus shipping,I don't think so! Thanks again,Wendell.
Z71Chevy #743455 04/29/2011 3:52 PM
We didn't pay any where near that amount for the last one we did.
Of course, I do a lot of business with them and don't have to pay shipping.
You can get the pump, brackets, & pulleys from any pick your part.
CPP sells the same kit but I don't know what their prices are. It's still the best set up I have found for TF trucks.
Fred
rfs56trk #743714 04/30/2011 7:06 PM
I put a CPP unit in a 58.The install requires moving the shocks,and some welding on the mounting brackets. I used a new tilt column and there inter connecting shaft since the shaft requires a offset. Much easier with the front fenders removed.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
hankrags #747899 05/18/2011 2:25 AM
Fred doesn't make any money promoting those kits. He just likes what they do...The ABS kit comes with a lot of stuff which accounts for what seems like a lot of money. Comes with the Toyota box, engineered mounting plate, pitman arm, drag link with new ends, hoses, steering column u-joint and a bushing. And it's not a simple bolt-in deal. Just try getting your old pitman arm off and you're already in a power struggle. I bent a cheap puller and couldn't get it off. Resorted to my old friend, Mr. Cutting Torch and then I borrowed a beefy puller from my neighbor, a Snap-on dealer. This to get the new one on and off in order to adjust the travel. It's not a project for the faint of heart or shallow of pockets! Once done, worth every penny and skinned knuckle.
Pic: https://picasaweb.google.com/orchidskip/PowerSteeringProject#
