5 members (Otto Skorzeny, klhansen, Wally / Montana, DadsFirstPickup, Tiny), 188 guests, and 4 robots.
Topics128,077
Posts1,056,017
Members48,433
#74217 03/04/2007 12:02 AM
Apprentice
Apprentice
Can I use a stock intake manifold with Fenton Headers?
#74218 03/04/2007 12:09 AM
Sure can.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#74219 03/04/2007 12:16 AM
Apprentice
Apprentice
Dave- Do I use the same hardware(bolts and clips)?
#74220 03/04/2007 12:18 AM
You need to make provisions for heat. There are pretty much 2 ways. Check out my pics to see a homeade water heat set-up. Do a search on intake heat. Happy hunting.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#74221 03/04/2007 12:35 AM
Yes,,you can use the same bolts and "holders".
Marty
#74222 03/04/2007 1:31 AM
And for the other option, exhaust heat from the Fentons to the stock intake, check out my pics.
Which one is better to heat the intake??? Take your pick! Too each his own!!!! Hope this helps and BTW....yes....if you want your engine to run efficiently, you will heat your intake!!
Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#74223 03/04/2007 2:07 AM
A little tip to help prevent leaks on the manifold-Replace the manifold bolts with studs, along with the 2 outside alignment studs for either studs or bolts, and replace the oe clamps with heavier parts to allow for better clamping force. I made new clamps out of 1/4" stainless steel. I have had no leaks since.
Bill Burmeister
#74224 03/04/2007 2:59 AM
Now why didn't I think of that? It sure would make it easier to get everything started..would support the headers...slide the intake on the rings...you could even have the oem clamps in place.
Great idea! I'm changing out to my rebuilt engine Tuesday...will give it a shot and report back! Thanks for the tip Bill!!
Dave
