1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74217 03/04/2007 12:02 AM | Joined: Feb 2007 Posts: 17 Apprentice | | Apprentice Joined: Feb 2007 Posts: 17 | Can I use a stock intake manifold with Fenton Headers? | | |
#74218 03/04/2007 12:09 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | | | |
#74219 03/04/2007 12:16 AM | Joined: Feb 2007 Posts: 17 Apprentice | | Apprentice Joined: Feb 2007 Posts: 17 | Dave- Do I use the same hardware(bolts and clips)? | | |
#74220 03/04/2007 12:18 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | You need to make provisions for heat. There are pretty much 2 ways. Check out my pics to see a homeade water heat set-up. Do a search on intake heat. Happy hunting. | | |
#74221 03/04/2007 12:35 AM | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Yes,,you can use the same bolts and "holders". Marty | | |
#74222 03/04/2007 1:31 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | And for the other option, exhaust heat from the Fentons to the stock intake, check out my pics.
Which one is better to heat the intake??? Take your pick! Too each his own!!!! Hope this helps and BTW....yes....if you want your engine to run efficiently, you will heat your intake!! Hope this helps.
Dave | | |
#74223 03/04/2007 2:07 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A little tip to help prevent leaks on the manifold-Replace the manifold bolts with studs, along with the 2 outside alignment studs for either studs or bolts, and replace the oe clamps with heavier parts to allow for better clamping force. I made new clamps out of 1/4" stainless steel. I have had no leaks since.
Bill Burmeister | | |
#74224 03/04/2007 2:59 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Now why didn't I think of that? It sure would make it easier to get everything started..would support the headers...slide the intake on the rings...you could even have the oem clamps in place.
Great idea! I'm changing out to my rebuilt engine Tuesday...will give it a shot and report back! Thanks for the tip Bill!!
Dave | | |
