| | | Forums66 Topics128,096 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Hi there. Long time lurker first time posting. Have a 59 3100 apache fleet 4 speed all stock. Nice daily driver for around town. Bought Patrick's 3.38 kit with the bearing kit and got it all in yesterday. Everything went fine but now at rpm it sounds noticeably louder. Idle sounds the same and everything seems OK but I was just wondering if these 3.38 ring and pinion kits have changed the rpm noise in your guys truck? Just want to make sure its the way it is and not something I screwed up. Thanks in advance for any info you can offer..
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Im not sure what you mean by louder. The RPM are lower then they were so the engine should be quieter. The exhaust might be louder because you are pulling harder. If you havn't changed the speedo gear you will be going faster then the speedo shows. How about the rear end? Does it sing or howl? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Never thought about the speedo gear. Will have to find one of those! RPM is lower for sure. Haven't had it over 50 mph that the speedo shows as the kit say to give it 100 mile brake in before trying highway speeds but 4th seems to have a lot left at 50 around town. Howl seems to be a good way to describe it when in motion. At idle sounds just as before but for sure in motion I have a louder "howl" then before. It gets louder faster and quieter as I slow and come to a stop. Exhaust then? Or might be something I missed in the rear? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Did you check the tooth pattern when you set it up? Does this howl vary by acelleration or deceleration? You may have to get good directions or a good book & set the tooth contact correctly. If that is the case you shouldn't drive it. If you wear 2 patterns in the gears they will never be right. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | What was in it before? If a 4.10, then you are probably doing 60, not 50. If the rear is howling you need to adjust it. Get the swipe pattern right, or you may be changing the rear again before you know it. Many guys here have done it, so there will be a lot of advice available. The rear set-up is on of those things you have to get right, close doesn't cut it.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Rear end gears are not something joe average can do. Have you done rear ends before? It can take hours to do correctly if you don't have the right tools for the job, and or experience. If it howls its most likely not set correctly, though if its not the mechanic it could be the gears, where are they made? China? Then I suspect the gears and not the tech.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | When I installed mine I noticed I can hear the transmission at low RPM. But that is it. Since the RPM is lower my exhaust aint so loud I cant hear rest of the truck. | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Thanks for all the info guys. Yes I have worked rear ends and have an understanding of how it goes. The gearing is from Patrick's and I'm not sure of where he has them manufactured. It was indeed the 4.10 and I think it's time to get back into it and adjust it a bit to see where I'm at. Easter Sunday seems a good a day as any. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | FWIW, I'm running one of Patrics 3.38 gear sets. When set up correctly, there is no howling. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Joshm, Did you use Patrick's installation kit (that includes shims, seals, and bearings)? I have not used the 3.38 set but I have used two of Patrick's 3.55 sets. I thought my Suburban was quiet before the conversion. It is even quieter after the conversion (and I think this is due to using all of the new bearings/bushings that come in Patrick's installation kit). As mentioned above, did you follow the ring & pinion adjustment and the ring & pinion backlash adjustment (using prussian blue )? Patrick's ring & pinion sets might be made in China, Mexico, or Michigan, but no one has reported quality problems in the past (of course, there might have been a recent bad production run, no matter where they were made). | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | There must be something that is off to give you a noticable howl. Did you perform the break-in on jackstands during the initial installation? This procedure will put the rear of the truck in the air and your run the truck in its highest gear at idle for 15 minutes. If you have an extra helper, have them get behind the truck and listen for gear whine.
Did you use a dial indicator to ensure the lash was correct? I have done three sets of gears and an increase in noise means something isnt right.
I have pretty much a step by step album on my Webshots page, feel free to check it out, the link is below......
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Thank you again for the advice! Done with Easter now off to get into the old bolt and see what's going on. Yes I did use both Patrick's ring and his install kit. Sweet I did not do the break in you mention as the directions I got didn't mention to do so. I have a helper and I'm going to get it right! I will update and get some pictures of my truck for a proper intro in the next couple days. One last question if I may? Several of you mention my speedo gear will need to be replaced in order to get an accurate speed. Where would I buy one? Looked at Patrick's and brothers withou luck. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter sells adapters. Since I was interested in adjusting for tires that were a wider than diameter than stock plus the 3.55 conversion (from 3.90), I bought a ratio adapter from the Speedometer Shop. It fits perfectly and is within 1% error. | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Once again thank you for pointing me on the right direction!
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Is there a website for these patrick gears?
