2 members (Gdads51, WICruiser), 84 guests, and 3 robots.
Topics128,268
Posts1,058,319
Members48,485
#740947 04/20/2011 4:48 PM
Can anyone provide guidance for installing windshield and rear window of 1952 Chevy PU? When and where does the mastic come into the process? Is it necessary?
Also, I broke a door glass while trying to get the wing assembly in( major frustration, poor language, and walking away for a few hours), any help on that would be appreciated, too.
http://www.stovebolt.com/techtips/windows/rear.html
Here’s a good article out of the tech section that helped me.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
9
9 Offline
The back glass is really tight, it definitely helps to have two people. I actually didn't lube it up at all, but it would have helped I am sure. I basically got one end or corner started an had a screw driver to help get the rubber over the lip. Be very careful cause I popped it off and smacked the glass and luckily didn't break it. It took us maybe 20 min or so. I also remember putting a lot of pressure on it with your hand staying flat, like you got to caress it and wiggle it to help it set in the rubber and the groove.
The door glass with wings wasn't that bad, but I would be (upset) if I broke the glass too, that is 30 bucks plus shipping for an new piece, plus clean up. Obviously you gotta try again, just be patient I guess and find the "right" angle to slide it in at.
Windshield is actually pretty easy. Get your rubber laid out on the ground, put your glass in it. Then key is to get a small rope not too thin and not too thick, stuff it in the groove that will be mating with the cab. Make sure you leave the excess rope on the inside of the windshield. Then have someone help you set it in place, have them push very lightly from outside and you on the inside, pull the rope and watch how the rubber slides right over the lip. IT is very easy and fast doing it this way, but definitely is nice to have someone on the outside putting pressure on it and following you as you pull the rope.
51' 3100 s10swap, 350, 5 speed, patina
http://67-72chevytrucks.com/vboard/showthread.php?t=382481
49' GMC 3100 future project
55.1' chevy future project
54' 6400 chevy dump truck all original
63' c-10 future project
kevin, there is a link in the tech tips that will take you to the Online shop manual project (if you do not have a shop manual) and it will help you some to. Those vent window assemblies are a little aggravating to say the least but after putting one in 3 or 4 times I finally got good at it.... now don't ask me why I had to take it out....well, one reason was a broken glass that the glass shop cut wrong!!
Kevin,
The door glass does require some finesse but patience is the key. I believe I started the vent frame in with the window down and rolled it up as I was sliding the vent frame down. I have done mine each twice ...they are not fun.
The windshield is the easiest to do. I sealed mine with butyl windshield sealer after I installed it (as I had leaks). I have never been able to do the rope trick. I just pull the rubber over the frame with my fingers and a pliers.
The rear window was the toughest for me. It took a lot of duct tape (holding the rubber on the glass) and the help of my 2 kids to have enough hands to get it in the frame. It just seamed that the rubber was impossible to handle. Installing the key is also tough but I sealed this window with silicone sealer.
Good luck
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
Good luck
Rich
Rich, your first mistake was to put the rubber on the glass, how then did you fit it,did you use the string method?
That's possibly why it was fighting you all the way.
The rear rubber is not designed for this type of installation.
Here's how the rears should be done.
I'm suprised your rubber didn't tear.
Rear window install.
It's good you got it done,but ran the risk of cracking your glass.
More pix on Flickr.
Jock
I did not realize that the gasket was cemented to the truck first. That does seem easier. Mine came out fine and has never leaked it was just a bear to install my way.
Rich
1953 3/4-Ton Chevy
More pix
RB53
Did you use cement on the rubber gasket to adhere it toi the frame?
Personally,I normally fit them dry,then using a caulking gun,inject a product called Arbomast between the body/rubber,and then the rubber/glass.
It makes the installation process easier and cleaner.
Arbomast is a non aggressive,silicon free,non setting glazing compound,you can also use urethane,although it can be messier!
I'd definately consider doing the fronts,the rubber profile is very basic compared to more modern styles and could probably use some help.
I'm leaving my rear glass dry as I think it'll be OK.(I'm sure it'll prove me wrong!) dang
If it is the fronts I simply clean off the excess/ooze with glass cleaner,a plastic scraper and finally with paint shop panel wipe.
With the rears I apply the sealer before the filler/lock strip goes in(much easier) then clean up in the same manner.
JMO.
More pix on Flickr.
I've been trying to preform the gasket on the rear glass before forming it to the cab, but it is really stubborn and keeps falling off.
FRUSTRATION!
Patience Grasshopper.......
Joking apart Kevin,it can be frustrating.
Try and fit the rubber to the cab aperature and if necessary use some masking tape to hold it,as I mention in my guide try and 'cram' the rubber as you go to ensure it's good and tight on the pinchweld.
Cut your ends as square as you can and allow an 1/8th to 1/4" oversize to allow for shrinkage and apply a small dab of rubber adhesive or superglue at a push.
I use urethane as it's what I've usually got to hand.
More pix on Flickr.
Thanks, I'll be back at it tomorrow.
