| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 |
Professional Novice
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Looking good! Are you concerned at all about water or mud splashing up on the engine without those inner fenders? Or are you only going to drive it on paved roads on sunny days?  | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | I was concerned about that myself before I made the change, but so far I haven’t seen any increase in engine compartment spray or splatter, and it’s been either raining or snowing consistently since I removed the inner panels. I believe this is because I left the complete inner fender in place above the tire so everything in alignment with the tire pretty much contains the spray as well as it did before.
I’m retired so the annual mileage is down, but it does get used all year not just in good weather. In the few months since the inner panels were removed, I’ve come to enjoy the modification so much it’s doubtful I’ll never go back to stock. I’m in my 60’s with a bad back and knees, and having everything open for easy access is worth any increase in cosmetic cleanup that may be needed.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...looks nice and those bed rails are like icing on a cake. Looks good.
Hey, I've ran the 37 for years without inner fenders. It seems I just can't make up my mine what I want to do.......and then got started on some other projects. You know how it goes with us "older" folks!! LOL | | |
