8 members (1955 1 Series, Chris's 46 / 515, bnauman, Otto Skorzeny, dt235sd, Peggy M, Phak1, 1 invisible),
66
Mod | | | Forums66 Topics128,175 Posts1,057,115 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 28 New Guy | | New Guy Joined: Sep 2010 Posts: 28 | Hey all, I'm thinking of replacing the 292 in my '65 P-30. Not having ever swapped out the 292 for a small block, I'm wondering how many parts will need to be changed, other than the obvious things like the exhaust system.
Thanks for any and all input. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | You will need to replace the passenger side motor mount bracket, it is particular to the 292. The radiator will need to be checked to see if it is a 2 or 3 row.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | if you have a clutch,I'm sure the linkage will be different,also the throttle linkage | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | there may be a little difference in the throttle linkage, but the clutch is the same ron | | | | | Joined: Apr 2009 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 94 | I am also interested in swaping my 292 in my 1966 GMC 960 for a 350 and am wandering where do i get the motor mounts?? Thanks
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | would have to see what the mounting looked like, but you would have to change that righ side to what a v8 used in that application. it is possible that the same from lessor models may work ron | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | Hey, If you are going to sell the 292 Chevy L6 let me know. I'm looking for one for a friend whom has money and a nice '52 Chevy business coupe to put it in. Normbc9 | | | | | Joined: Oct 2010 Posts: 21 New Guy | | New Guy Joined: Oct 2010 Posts: 21 | I have a 59 1/2 ton that I installed a small block in it. The front mount you can buy in a kit. It will slide thru the frame and you bolt the outside to the frame and weld the two ends. The rear mount will be bell housing or mount to rear of the automatic transmission.
I have two 292 Chevy 6 motors I would like to sell. They are all apart so you can see what your getting. I live in sol calif. Handtight
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I live in Vacaville so the drive is just six hours plus my home is in Julian where I have family. I am interested and am a cash buyer for a friend. Email me and we can arrange a date to meet and get the transaction done. Normbc9 | | | | | Joined: Oct 2010 Posts: 21 New Guy | | New Guy Joined: Oct 2010 Posts: 21 | You can email me at [email protected] handtight
