Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Simon1954, KingG), 56 guests, and 4 robots.
Topics128,009
Posts1,055,297
Members48,419
#73903 02/26/2007 3:53 AM
Just finished up the install of Langdon's Carter/Weber carbs on my Offy manifold. Hooked up both auto chokes, set the fuel pressure for 3.5 psi, a little squirt of starter fluid and it fired immediately. Did a quick "by ear" carb sync, backed off the idle speed screws equally, hooked up the linkage. Idle mixture out of the box gave me 19" vacuum.
Best part is that it drives like a dream. Haven't had a chance to check the mileage but I'll be disappointed if I can't nurse out 20 mpg.
Another satisfied Langdon customer! Pic in "Tips and Tricks".
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#73904 02/26/2007 6:11 AM
If you start having problems with too much choke, don't be afraid to disconnect one. Usually that's all you need and it makes it easier to adjust. But if it works the way you have it, leave it be.
Fred
52 3600
69 C-10
#73905 02/26/2007 6:22 AM
Dave,
Your work on the intake manifold, carbs, linkage, and tubing is impressive and an inspiration.
Very nice.
Tim
#73906 02/27/2007 1:16 AM
Lookin' good, Dave!
#73907 02/27/2007 4:44 AM
cool
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
