| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73903 02/26/2007 3:53 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just finished up the install of Langdon's Carter/Weber carbs on my Offy manifold. Hooked up both auto chokes, set the fuel pressure for 3.5 psi, a little squirt of starter fluid and it fired immediately. Did a quick "by ear" carb sync, backed off the idle speed screws equally, hooked up the linkage. Idle mixture out of the box gave me 19" vacuum.
Best part is that it drives like a dream. Haven't had a chance to check the mileage but I'll be disappointed if I can't nurse out 20 mpg.
Another satisfied Langdon customer! Pic in "Tips and Tricks".
Dave | | |
#73904 02/26/2007 6:11 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you start having problems with too much choke, don't be afraid to disconnect one. Usually that's all you need and it makes it easier to adjust. But if it works the way you have it, leave it be.
Fred 52 3600 69 C-10
#73905 02/26/2007 6:22 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
Your work on the intake manifold, carbs, linkage, and tubing is impressive and an inspiration.
Very nice.
Tim | | |
#73906 02/27/2007 1:16 AM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | | | |
#73907 02/27/2007 4:44 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | | | |
