0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#738532 04/12/2011 12:45 PM
Mortec.com isn't currently working and I haven't found another place to check yet.
Engine # is gone but the CASTING is 3970010
That block was used as both a 302 in 69' Z-28 Camaro and 69-80' as a 350 with both 2 and bolt mains according to Mortec.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
3B Offline
Hy Achipmunk, that block was used for any 4" bore application 302, 327, and 350, it is a post 1968 block [large crankshaft bearings], and I've seen them in both two bolt, and four bolt main configuration. I don't know when they stopped using the number, but 1985 would be the newest [1986 was the first year for the one piece rear main seal I believe], hope that helps some.
Thank you Dave and 3B. Its what I needed to know.
69 to 79. 80 they changed dipstick side and 86 to 1 piece rear seal
50 chevy 3100
