1 members (baldeagle),
96
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | 1949 216 engine with a side mounted oil restricted flow oil filter. It seems that these units filtered very little oil and thus would have a very limited affect in keeping the oil clean. Can this limited flow oil filter be converted to a full flow, and how could it be done? Further, should I even consider changing it or leave well enough alone? Thanks for the help.
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
The by-pass oil filters work fine. They may only filter a small % of the flow, but all of the oil eventually goes through the filter and gets cleaned.
Someone else will have to comment on changing a 216 to allow a full flow oil filter.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I wouldn't change it either. I don't even have a filter on my truck. It gets driven 300-500 miles a year - maybe. So I just change the oil and I'm happy. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I wouldn't change it either. I don't even have a filter on my truck. my 40 was like that. when i had a 270 for the 40 and the ashton rebuilt that is when i did the full flow conversion with a remote filter housing while the engine was dismantled. when i had the 59-235 rebuilt for the 51-6100 i decided for how much running time it would have i decided to just go with the bypass filter. i just got a dmv annual inspection last thursday on the 6100. total mileage for the year was just over 1000 miles. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | If anything, a bypass filter does a better job of cleaning up the oil- - - - -it just takes a little longer. Converting a 216 to full flow would be a big job, involving some very creative machining. Untold numbers of these engines ran millions of miles with the oil system it was designed to use- - - -why second-guess something that works because of the ridiculous rumor that the filtering is ineffective? Jerry
| | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Guys:
You sold me, I'll leave it alone, I greatly appreciate the insight. Good to hear from you Jerry, and all you folks here at the Stovebolt. Be well.
Dave
| | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I have a 216 with the old style filter that I still have as a Babbitt Pounder. It now has over 100,000 miles on it and going strong. If there were oiling issues I would have detected it by now. I use a high grade 10-30 motor oil with no other additives. I'm going to pull the head to take a look at the upper end soon. I did replace all the valves and seats when I built it up. I'm using a 248 GMC rocker assembly that I had the towers machined down to the length of the stock Chevy towers. That is still functioning well. I have an HEI unit on it and also a dual intake with heat and Carter/Webers from Stovebolt and cast iron headers. Normbc9 | | |
