5 members (jmoore, Woodcmiami, Ludwig.van.dille, Shaffer's1950, 1 invisible), 87 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
#73695 02/22/2007 3:56 AM
Hi, my profile is a little outdated, i have a 54 1st series 3100 that i am going to use a chevy 82 s-10 frame under. I have been going over all the options for motors and then i stummbled across a 1978 Buick 3.8L turbo v6 with tranny, wiring and rear end. the first thought in my head was, can it be done?...has it been done?
Tony
old iron vs. new plastic....no brainer!
TECH WANTED: on S-10 frame swap
PARTS WANTED: 54 Visor, weather strips..
PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate
1954 GMC 3100
#73696 02/22/2007 4:04 AM
I'm wondering if that 3.8 wouldn't just bolt right in to where the 2.8 or 4.3 was on that s-10 frame. I like the idea of a turbo powered jimmy cool
#73697 02/22/2007 6:12 AM
I've seen one in an AD but don't recall what frame was used. Go for it.
#73698 02/22/2007 8:43 AM
The 3.8L takes a BOP bellhousing but it is pretty compact. I used to have a CJ-5 with a Buick 225 (same dimensions) shoehorned into it, it actually had enough room under the hood to work. With a 4bbl Qjet on an Offy manifold it was scary fast- the Jeep only weighed about 1800 pounds.
I don't know how you will fit the turbo in there but if you use a passenger side exhaust manifold on the driver's side for a front dump exhaust you don't have to move the steering box.
Paint & Body Shop moderator
#73699 02/23/2007 1:48 AM
The original prototype for the Syclone had the 3.8 turbo in it. This truck was built on the 2wd S10 chassis, though never saw production. Shouldn't be any issues with fitment as long as you have the correct mounts and tranny.
Bill Burmeister
#73700 02/23/2007 2:50 AM
Quote
Originally posted by LONGBOX55:
. Shouldn't be any issues with fitment as long as you have the correct mounts and tranny. [/QB]
i was thinking that i would use the same tranny behind it..
1954 GMC 3100
#73701 02/23/2007 3:49 AM
What car is this motor coming out of? If you can grab the motor mounts they may easily adapt to the S-10 frame.
I don't know that its been done but why not do it?
#73702 02/23/2007 3:58 AM
One more thing about the S10-the chassis from the front cab mount forward is essentially the same as the late '70s/early '80s downsize GM intermediates (Malibu/Cutlass/Grand Prix/Gran Sport). So The motor mounts for the Buick engine should be able to be used with the S10 chassis. Also, all of the front end components will swap, like ball joints, tie rods, shocks, etc. You can also use the car shocks on the rear, especially if it's been lowered.
Bill Burmeister
#73703 02/23/2007 5:36 AM
Quote
it is coming from a 78 regal(g-body), the car is at my diposal. I figured the engine mounts would work also and other things such as tilt steering, wiring harness, maybe power window motors would work also. Im not sure about the turbo hood scoop though ..lol eek
1954 GMC 3100
#73704 02/25/2007 9:13 PM
ttt
1954 GMC 3100
