| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73695 02/22/2007 3:56 AM | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | Hi, my profile is a little outdated, i have a 54 1st series 3100 that i am going to use a chevy 82 s-10 frame under. I have been going over all the options for motors and then i stummbled across a 1978 Buick 3.8L turbo v6 with tranny, wiring and rear end. the first thought in my head was, can it be done?...has it been done? Thanks, Tony
old iron vs. new plastic....no brainer! TECH WANTED: on S-10 frame swap PARTS WANTED: 54 Visor, weather strips.. PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate 1954 GMC 3100 | | |
#73696 02/22/2007 4:04 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I'm wondering if that 3.8 wouldn't just bolt right in to where the 2.8 or 4.3 was on that s-10 frame. I like the idea of a turbo powered jimmy  | | |
#73697 02/22/2007 6:12 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've seen one in an AD but don't recall what frame was used. Go for it. | | |
#73698 02/22/2007 8:43 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The 3.8L takes a BOP bellhousing but it is pretty compact. I used to have a CJ-5 with a Buick 225 (same dimensions) shoehorned into it, it actually had enough room under the hood to work. With a 4bbl Qjet on an Offy manifold it was scary fast- the Jeep only weighed about 1800 pounds.
I don't know how you will fit the turbo in there but if you use a passenger side exhaust manifold on the driver's side for a front dump exhaust you don't have to move the steering box.
#73699 02/23/2007 1:48 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The original prototype for the Syclone had the 3.8 turbo in it. This truck was built on the 2wd S10 chassis, though never saw production. Shouldn't be any issues with fitment as long as you have the correct mounts and tranny.
Bill Burmeister | | |
#73700 02/23/2007 2:50 AM | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | Originally posted by LONGBOX55: . Shouldn't be any issues with fitment as long as you have the correct mounts and tranny. [/QB] i was thinking that i would use the same tranny behind it..
#73701 02/23/2007 3:49 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What car is this motor coming out of? If you can grab the motor mounts they may easily adapt to the S-10 frame.
I don't know that its been done but why not do it?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#73702 02/23/2007 3:58 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | One more thing about the S10-the chassis from the front cab mount forward is essentially the same as the late '70s/early '80s downsize GM intermediates (Malibu/Cutlass/Grand Prix/Gran Sport). So The motor mounts for the Buick engine should be able to be used with the S10 chassis. Also, all of the front end components will swap, like ball joints, tie rods, shocks, etc. You can also use the car shocks on the rear, especially if it's been lowered.
#73703 02/23/2007 5:36 AM | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | Originally posted by OldSub: What car is this motor coming out of? If you can grab the motor mounts they may easily adapt to the S-10 frame.
I don't know that its been done but why not do it? it is coming from a 78 regal(g-body), the car is at my diposal. I figured the engine mounts would work also and other things such as tilt steering, wiring harness, maybe power window motors would work also. Im not sure about the turbo hood scoop though ..lol
#73704 02/25/2007 9:13 PM | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 |
