Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (klhansen, EddieD, Tyler Watts, KEVINSKI, UtahYork, 2 invisible), 43 guests, and 4 robots.
Topics128,009
Posts1,055,291
Members48,419
#735993 04/04/2011 1:57 AM
Hey guys, I guess I'm just excited but wanted my panel and suburban friends to know I'm still pecking away on the 52.
Here is a couple updated shots with the grille,bumper,valance,parking lights and the HOOD...yippeeee. Got it out of the floor after 2 years or walking around it.
But, as you can see, the hood is in BAD need of adustment. I'm dreading it and decided to take a day...or two off. I've read the post and the tech tips but it sure looks like its got a loong way to go. And loosing the hinges inside it will only move so far....so where does the adjustment really come from??
Heres the pics.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0254.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0253.jpg
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0252.jpg
I'm filled with envy Alvin.
From what I understand, you first align the hood to the cowl, then align everything else to the hood.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
The Ned #736067 04/04/2011 11:45 AM
Leo Offline
Moderator
Moderator
Looks good Alvin, you've added the cowl induction option, like me. I've been wondering about how to get that down too. Is yours worse on the passengers side? Does the front of your hood touch the grille when its closed? I was told to check for worn hood hinges but they are fine. You're right about taking a day or two to think about it, I'll help you with that.
Leo
Leo #736195 04/04/2011 8:20 PM
Z
Z Offline
Looking good Alvin,are you putting any graphics,on the side?I was looking at your grill,you might have to paint them black,from the pictures the grey bars behind the chrome,stands out more than the chrome.In my opinion,and it really looking good, glad of your progress. Stay in touch.Wendell
Looks great Alvin,sorry I can't help with the hood,I guess I was lucky with mine,so I can't offer any advice/tips.
I assume the hood was a good fit before you tore it down?
This is probably too late for you, but before I tore my truck apart,the hood fit was good.
I scribed heavily around the hinge mounts deep enough so that even when it was painted the lines showed.
Once the hinges were re-installed you can hardly see any marks.
Incidentally I don't know if this helped as well but I fitted the hood first,then built up the front clip.
Hopefully others who read this might avoid similar problems.
More pix on Flickr.
Leo, it looks close to the same on each side.
Wendell, all kinds of "notions" going around in my head. What you think about a scene with the CHIPMUNKS smile Oh, the back splash bars look grey in the picture but they are actually powdered coated a cream color. I was unsure about them and will wait a while to judge it. If anything I will go back and paint them body color.... I think!
John, when I purchased the panel the front end had been totally taken off. I can't say for sure about the hood but I believe it had been moved to. I did scribe around them but in the end it wasn't deep enough. I learned here, after the fact, to drill and put in a little roll pin!
I might add that yes, as it sits now, the front of the hood barely touches the top grille bar but once the back goes down I think it'll be alright. In all truth, the front of the hood, from side to side, is pretty dang good where it fits down in the fenders. I have left the latch panel off for now untill get t he hood set.
I am going back and re-read the tips on it and I have some topics that I printed out some time ago knowing dang well I'd need them. So, for the next day or two, Leo and I smile are going to think about it and then proceed very carefully.
Thanks for your comments guys... and for your help and inspiration. I'd probably give up on this one a long time ago but didn't want you guys calling me a quiter smile
Y
Y Offline
Sweet!! Great looking panel. I guess I'm just lucky, but on my 51 & 53 the hoods were easy to adjust, just by following the tech tips. Becareful and protect the cowl & fender paint, because if the hood moves, of course it going to eat the purty paint!!
Alvin,
Your panel looks real nice.
Most likely you have already followed the hood-adjustment/alignment Tech Tip.
We got my Suburban hood sitting better after following that procedure.
Good luck.
Z
Z Offline
Hello,again Alvin,you must have read my mind,about Alvins Chipmunk theme on the side.I thought about suggesting that in my previous comment earlier. The color of the bars on your grill,would definetely look good as the same color of the body.Good luck with your hood alignment.Keep on Trucking!
Ha Achimunk just went through the hood set up before painting i did set the hood to the cowl and then the fenders and grill.Not easy took a lot of time and i did use a little filler in the back corner/curves.I had to give up on the springs that hold the hood up when open i just could not get the rear of the hood to settle on the cowl seal.I hope to fix that later but it's a stick to keep it up for now.
Wounderful job, enjoy.
Len
layback
Alvin, I am proud of you, that is one fine panel. I went through the hood episode as well. I used the tech tip and got it as good as I can. Not perfect but after seeing others at shows and cruises mine doesn't look too bad. I spent the better part of 2 days on the hood. Working on the headliner now. Another fine mess. Will I get to meet you in Kansas City in September? I plan on driving the sub for the Stovebolt reunion on the 9/10/11th.
Weeds
Weeds #736978 04/07/2011 4:22 AM
Thanks Weeds, but I"ve told you all along YOUR an inspiration.
Yes, if all goes well I'll be in Kansas. Great folks and good trucks. Just can't get any better.
Leo Offline
Moderator
Moderator
Alvin, My hood was up about an inch on the passenger side, not bad on the driver side. After a few weeks of use, it has settled down, can hardly get my pinky finger in the gap anymore. I'm finished messing with it, what have you come up with?
Alvin,
I won't make it to your cook-out in June. However we will be coming down in Sept to see my cousin in Boiling Springs and while we are in town would like visit you and Ronnie. I'll bring my build book on the 52pu. Please send me your phone and address.
Tim
52pu
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
52pu #749439 05/24/2011 5:01 PM
I had same issue as Len in that with hood springs I couldn't get the hood lay to cowl. I quit trying as I have many other areas before I worry about good alignment.I will reread tech tips but any advice appreciates. Chipmunk congrats as the panel looks great. Enjoy the ride.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Congratulations on a job well done, that's one fine looking Chevy
You have done a beautiful job on this truck. I am going to be starting a project on a 1950 3800 Panel once the snow melts and I go pick it up smile.
Too many projects not enough time.
1950 3800 Chevy Panel Truck
Mr. Yard Rodent, wink YOU inspire us all. Please post before and after pics so folks can see what really has been DONE!
later,pal,
Les
