| | | Forums66 Topics128,089 Posts1,056,005 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73632 02/21/2007 3:25 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | So I'm converting my idiot light type cluster to all gauge type on my 1960 C-10 does anyone know where I can get the tube setup or what I actually need to get the guage hook to the engine. -Help!
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
#73633 02/21/2007 4:38 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | When I switched from the idiot lights to Dolphin gauges for my 235, I just bought a sending unit from the flaps. I think the application was for a 283 of that era. There is just a wire from the gauge to the unit. It reads at 170 once warmed up. I have yet to check accuracy, but I think it's close as my truck runs cool. | | |
#73634 02/21/2007 4:40 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bigmacdaddy, Men have killed for 170 lbs of oil pressure, consider yourself very lucky. Stuart | | |
#73635 02/21/2007 4:45 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | OOps. So we're talking about the oil pressure gauge -- rigghtt. My bad. In that case, THAT sending unit came with my gauges from Dolphin. Same thing though, there is wire to the larger than stock unit from the gauge. No tubes. | | |
#73636 02/21/2007 11:20 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have a mechanical gauge that uses a tube you can get a kit at any parts store. It,s a good idea to put vacuum hose over it where it might rub something like going through the fire wall & support it good. If it fails it can ruin the engine. If it is an electric gauge you need a sender to match the brand of gauge. You use the outlet the light sender is in. If you want to use both you can get a pipe T. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73637 03/03/2007 9:40 PM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Thanks Wrenchbender, I ended up getting a kit but had to make some mods for the connecting the line to the gauge, no biggie, thanks again to all
