1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
So I'm converting my idiot light type cluster to all gauge type on my 1960 C-10 does anyone know where I can get the tube setup or what I actually need to get the guage hook to the engine. -Help!
Thanks,as always -Danny
1960 C-10 Stepside,Longbox
235,4spd 3.90 diff.
When I switched from the idiot lights to Dolphin gauges for my 235, I just bought a sending unit from the flaps. I think the application was for a 283 of that era. There is just a wire from the gauge to the unit. It reads at 170 once warmed up. I have yet to check accuracy, but I think it's close as my truck runs cool.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
bigmacdaddy,
Men have killed for 170 lbs of oil pressure, consider yourself very lucky. wink
Stuart
OOps. So we're talking about the oil pressure gauge -- rigghtt. My bad. In that case, THAT sending unit came with my gauges from Dolphin. Same thing though, there is wire to the larger than stock unit from the gauge. No tubes.
My Webshot Photos]
Riding in the Passing Lane
If you have a mechanical gauge that uses a tube you can get a kit at any parts store. It,s a good idea to put vacuum hose over it where it might rub something like going through the fire wall & support it good. If it fails it can ruin the engine. If it is an electric gauge you need a sender to match the brand of gauge. You use the outlet the light sender is in. If you want to use both you can get a pipe T.
1972 Chevy c10 Cheyenne Super
Thanks Wrenchbender, I ended up getting a kit but had to make some mods for the connecting the line to the gauge, no biggie, thanks again to all
235,4spd 3.90 diff.
