3 members (Lostbuthaulinass, MNSmith, festerhairball), 99 guests, and 2 robots.
Topics128,057
Posts1,055,814
#73560 02/19/2007 8:00 PM
I want to change my gears in my rear end to see if I can get a little more go...What do you all suggest?
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
#73561 02/19/2007 8:40 PM
Holcomb: Depends on what you mean by "a little more go". Are you looking for more top end? better acceleration.....? And, are you running a V-8, 235, 216, and then there's the trans, is it the stock 3-speed, 4-speed, overdrive, auto???? Do you know what ratio your rear gear is now? All of these things will play into the mix in determining what you want to do with your rear end gearing.
#73562 02/19/2007 10:13 PM
I'm running a 216, 4 speed...now at 55 it seems like it is running very hard just keep that speed..the rpms are high...it has the stock gears in the back. I thought maybe changing the gears in the rear end would solve that...
1951 3100
Pablo Picasso
#73563 02/19/2007 10:24 PM
Riding in the Passing Lane
You can get 3.55 gears from most of the parts suppliers for these old trucks. It will make 65 or so comfortable.
1972 Chevy c10 Cheyenne Super
#73564 02/19/2007 11:42 PM
Cool thanks guys...
1951 3100
Pablo Picasso
#73565 02/20/2007 12:46 AM
You might want to buy the installation kit when you buy the ring and pinion gear. It contains the bushing, bearings, seals, and gaskets that will most likely be required.
#73566 02/20/2007 4:37 AM
After I installed my O.D., 65 was easily obtainable at pretty low RPMs but was still not "comfortable" due to the split rims and skinny tube-type tires. At 65 my knckles were white and the truck was all over the road. When I switched to radials the ride and handling at 65 was what I dreamed it could be.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#73567 02/20/2007 7:44 AM
Holcomb; The 3:55 gear set that Patrick's sell sounds right down your alley. It should allow you to cruise at 65 with ease. Good luck.
#73568 02/20/2007 3:57 PM
Consider a brake upgrade if you plan on going 65!
#73569 02/23/2007 2:01 AM
Thanks again guys...I will check out 3:55 gears. Anybody know where to buy those? Is it a specific brand name I should look for?
1951 3100
Pablo Picasso
#73570 02/23/2007 2:54 AM
Patrick\'s
Give them a call and they'll send needed parts right out. Most of the "Catalog" stores order these kits from Patrick's. Also, I agree that you should go ahead and purchase the whole rebuild kit rather than just the gears - do it right the first time, unless there's time to do it again.
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
