Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (KEVINSKI, 68ironhead, 1 invisible), 103 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#73503 02/18/2007 7:03 PM
My Muncie 420 leaks pretty bad...over spring break I want to overall it... The transmission shop wanted me to order the gasket set, and rear bearing (tail shaft)
What other parts do I need to buy?
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
#73504 02/18/2007 7:07 PM
You might need 2 new synchros. One of the synchros is built into a gear and that one is typically not real worn unless its had some serious grunt done to it. I was always taught if your gonna replace one bearing replace them all. You can get the complete set, (all bearings, needle bearings, gaskets, including 2 synchros, etc...) for less then 200$.
Its kinda funny cause I just tore one down last night!
Jeff
My 1953 Chevrolet
1947.1 Gallery
#73505 02/18/2007 7:11 PM
Riding in the Passing Lane
You can buy a complete o-haul kit that includes brgs, seals & snap rings etc. I f it is working ok & just leaks you can put seals & gaskets in it yourself. You certainly want to put the front drive brg. in if you o-haul it. That one usually goes first. If it makes more noise than usual in the lower gears & is quiet in high it is a good indication the front drive gear bearing is bad.
1972 Chevy c10 Cheyenne Super
#73506 02/18/2007 8:05 PM
Ya it doesn't make any noise...just leaks...the transmission shop wanted me to get all the parts needed to do the work...Just wanted to be prepared when he takes it...that way I have all parts needed in case
1951 3100
Pablo Picasso
#73507 02/18/2007 8:07 PM
Where do guys suggest I look for parts? What should I buy exactly? I'm at the end of my budget....
1951 3100
Pablo Picasso
#73508 02/18/2007 9:52 PM
Heres a few places from the links section on this site.
http://www.novak-adapt.com/catalog/sm420_parts.htm
http://www.hermtheoverdriveguy.com/id3.htm
If you feel up to it, I dont think its a real complicated overhaul. I pulled mine apart in a few hours time and the only tools I needed were a handful of sockets, hammer, gear puller, punches, snap ring pliers and a punch. Youll feel pretty good about doing it yourself if you feel up to it!
Heres a helpful write up listed in the parts section and if you have a service manual that pretty much walks through most of the stuff to tear it apart.
http://members.cox.net/cglabe1/SM420/sm420.html
Jeff
My 1953 Chevrolet
1947.1 Gallery
#73509 02/18/2007 11:02 PM
Thankyou
1951 3100
Pablo Picasso
