| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73503 02/18/2007 7:03 PM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | My Muncie 420 leaks pretty bad...over spring break I want to overall it... The transmission shop wanted me to order the gasket set, and rear bearing (tail shaft)
What other parts do I need to buy? | | |
#73504 02/18/2007 7:07 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | You might need 2 new synchros. One of the synchros is built into a gear and that one is typically not real worn unless its had some serious grunt done to it. I was always taught if your gonna replace one bearing replace them all. You can get the complete set, (all bearings, needle bearings, gaskets, including 2 synchros, etc...) for less then 200$.
Its kinda funny cause I just tore one down last night!
Jeff | | |
#73505 02/18/2007 7:11 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can buy a complete o-haul kit that includes brgs, seals & snap rings etc. I f it is working ok & just leaks you can put seals & gaskets in it yourself. You certainly want to put the front drive brg. in if you o-haul it. That one usually goes first. If it makes more noise than usual in the lower gears & is quiet in high it is a good indication the front drive gear bearing is bad. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73506 02/18/2007 8:05 PM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Ya it doesn't make any noise...just leaks...the transmission shop wanted me to get all the parts needed to do the work...Just wanted to be prepared when he takes it...that way I have all parts needed in case | | |
#73507 02/18/2007 8:07 PM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Where do guys suggest I look for parts? What should I buy exactly? I'm at the end of my budget.... | | |
#73508 02/18/2007 9:52 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Heres a few places from the links section on this site. http://www.novak-adapt.com/catalog/sm420_parts.htm http://www.hermtheoverdriveguy.com/id3.htm If you feel up to it, I dont think its a real complicated overhaul. I pulled mine apart in a few hours time and the only tools I needed were a handful of sockets, hammer, gear puller, punches, snap ring pliers and a punch. Youll feel pretty good about doing it yourself if you feel up to it! Heres a helpful write up listed in the parts section and if you have a service manual that pretty much walks through most of the stuff to tear it apart. http://members.cox.net/cglabe1/SM420/sm420.html Jeff | | |
#73509 02/18/2007 11:02 PM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | | | |
