3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Hey guys, Brand new to this site, Thanks for having me. I'm brand new to these forums so please forgive me if I goof on this, my first post. I recently acquired an all stock 53 3/4 ton, long box with 216 and 4 speed on the floor. I've been doing repairs since it got here to FLA. just before Christmas last year. I am having difficulty gathering info on fluid type, location and levels. Specifically the trans, torque tube, rear end, etc. Need advice on motor oil type and quantity as well. This truck is extremely original, I do not believe it has been modified whatsoever. I sincerely appreciate any help/guidance I can get. It's ready to be put back on the road once the fluids are back in. Thanks. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | To each his own but for me, and its original, I"d run 30wt. motor oil, 85-90 gear lube. As far levels go you simply unscrew the plug on the back of the rearend and fill it till it wants to overflow... but be sure the vehicle is sitting on lever ground. Also, take the fill plug out of the tranny and do the same thing. ...and of coarse you know where the dipstick is to check the engine oil.
I'm sure others will chip in later with their opinions.
And welcome to the Stovebolt. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Thanks to everyone for their help. I hope to one day return the favors. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | | | |
